Author Topic: killer white smoke  (Read 2099 times)
November 10, 2008, 07:56:12 am
96jetta
killer white smoke
« on: November 10, 2008, 07:56:12 am »
i just finished doing the head guasket and timing belt in my 96 td 1.9L jetta. it kinda runs but hesitates a lot then runs for a bit putting out a lot of white smoke. i was told it was the fuel injection pump was timed wrong and as much as i play with it it doesnt do a whole lot.
PLEASE HELP!! thanks Geoff
Reply #1November 10, 2008, 08:03:53 am
zozep
  • 176
killer white smoke
« Reply #1 on: November 10, 2008, 08:03:53 am »
I just did the same on my 92 1.6TD, MHG, timing belt etc... on a cold start it will blow out alot of white smoke until it gets warm, then it runs just fine.
SOLD: 92 Jetta TD, Giles Pump set to 30 psi, MLS Head Gasket, ARP head studs, Huge eBay intercooler, blocked WG, FK suspension, 1.9L AAZ downpipe to 2.5 inch straight back.
Current: 2000 TDi, 01M :(  DG Full skid plate, Cat 2 micron Fuel Filter, Scanguage II, 4700kHIDs, DG RacePipe
Reply #2November 10, 2008, 09:09:55 am
killer white smoke
« Reply #2 on: November 10, 2008, 09:09:55 am »
How long has this been happening Geoff?
Could be as mentioned either the timing is off and/or there is some antifreeze in the exhaust. The later would burn off after a short drive though and not return.
EDIT; Is this a TDI or an AAZ 1.9?
Reply #3November 10, 2008, 09:26:00 am
killer white smoke
« Reply #3 on: November 10, 2008, 09:26:00 am »
Sounds like timing. Based on your description you have a single piece pump pulley right?
Reply #4November 10, 2008, 09:34:22 am
killer white smoke
« Reply #4 on: November 10, 2008, 09:34:22 am »
Timing and/or air bubbles would be my guess as well.
