Author Topic: Exhaust/inlet manifold with VNT 20  (Read 3528 times)
November 08, 2008, 08:16:01 am
BGA
  • 48
« on: November 08, 2008, 08:16:01 am »
I am building a mTDI with GT2052V turbo and VE pump with 12mm head.
I found a gasser exhaust manifold where number 1 and 4 cylinder are connected to one port and 2 and 3 to the other. Has this manifold any advantage over the 1.6 TD (4 to one port) manifold? What inlet manifold is suggested for this mTDI spec? 130 PD?
          http://picasaweb.google.se/bogunnar.andersson/Manifold02#[img]
Bo Gunnar
Reply #1November 08, 2008, 08:31:04 am
lbreton
  • 56
« Reply #1 on: November 08, 2008, 08:31:04 am »
I would say that manifold would be a disadvantage unless you have a lot of space to bolt on a longer 2-1 collector to match up to your turbo housing inlet.  With that short spacer block I see in the pic, there is probably going to be a lot of turbulence pulling it together with such sharp angles. That would be a loss in performance.
'97 F250 5.9 Cummins, POD's, PDR cam, Custom Pump, Stage II Port, 14CM, blabla
'92 Passat Syncro- AHU eTDI, PP520's, 2.5 Str
'99 Audi A4 Quattro - 2.0 BHW TDI, EDC15P, GT2056V, AWIC, 5Speed Euro Tranny - 214Whp/363TQ
Reply #2November 11, 2008, 02:19:01 pm
Whitbread
  • 28
« Reply #2 on: November 11, 2008, 02:19:01 pm »
If you're going through all that trouble, time, and money, don't skimp out on a manifold now. If you're got the room and skills, build a tubular one. The 4-1 stainless tubular header I built for my car cost less than $150 including the laser cut flanges. If that's not possible, just use the 1.6td manifold. The split runner gasser one is designed for a NA gas applications, not TD's. Take a look at how long the transition pipe is from where it goes to 2 finally down to 1 pipe is. It's that long for a reason.
Nice to see you over here too synchro  :wink:. Your sig is rather easy to spot haha.
02 Jetta ALH TDI, 2260vk+02M
97 B4V ALH TDI, compound turbos + haldex awd
81 Caddy MTDI AHU
07 Arctic Cat 700 turbo diesel
90 Corrado ALH, 02M + haldex in progress
87 K10, Detroit 4-53T with twins
04 BEW going in 91 Ski Challenger boat
