Author Topic: 81 caddy 1.6D no fuel from IP no elec. power  (Read 2365 times)
November 07, 2008, 05:24:18 pm
dieselherb1
  • 354
« on: November 07, 2008, 05:24:18 pm »
Just got this truck, guy said it hasn't run in a year then rough running. It has no elec. power except to the starter, engine turns over fast but no fuel out of the IP. I feed the IP from a 16oz bootle fuel going in none out. Run a jumper to the fuel solenoid(it clicked) still no fuel. Baffled about no electric power. Help Please
Reply #1November 07, 2008, 07:02:38 pm
VWCaddy
  • 85
    • VW Caddy Page
« Reply #1 on: November 07, 2008, 07:02:38 pm »
Is the timing belt intact?
For power, is the battery good?  Is there a small cable hooked to the + post along with the large cable to the starter?  Might be that small cable is defective.
'82 VW pickup, 1.9D engine, Missing LinkZ shift linkage
Reply #2November 07, 2008, 07:06:05 pm
blkboostedtruck
  • 1535
« Reply #2 on: November 07, 2008, 07:06:05 pm »
sounds like the pump has issues?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #3November 08, 2008, 03:50:51 am
ilikevwdiesel
  • 1202
« Reply #3 on: November 08, 2008, 03:50:51 am »
Is this the silver truck that was on Richmond craigslist? I saw one for sale on there. Sounds like the IP is junk. Remove the out bolt on top of the pump, fill it up with fuel and crank it with a jumper wire on the pump solenoid. If fuel gushes out put the bolt back in and try to start it. You may want to test all the glow plugs first, or at least hotwire the bus to make sure it's powered.
My Bio
Reply #4November 09, 2008, 05:08:51 am
dieselherb1
  • 354
« Reply #4 on: November 09, 2008, 05:08:51 am »
Yes this is the Richmond Craigslist caddy. Good battery, it has 2 small wires coming from the + post on the battery. Plan on checking the IP today. Never run across a vw with "no" power to the accesories-lights.
Reply #5November 09, 2008, 05:45:32 am
ilikevwdiesel
  • 1202
« Reply #5 on: November 09, 2008, 05:45:32 am »
you might want to give all the battery ground connections a good cleaning, that can cause trouble too. take a pair of jumper cables and connect them between the engine block and the battery ground and see if that helps things.
My Bio
Reply #6November 09, 2008, 05:21:33 pm
dieselherb1
  • 354
« Reply #6 on: November 09, 2008, 05:21:33 pm »
Got it started, body ground wire missing. But engine sounded like it was trying to beat the head off then stopped. Need to pull the valve cover and head maybe.
Reply #7November 09, 2008, 05:45:53 pm
ilikevwdiesel
  • 1202
« Reply #7 on: November 09, 2008, 05:45:53 pm »
Quote from: "dieselherb1"
before you do that why don't you make sure the valve and pump timing are correct, check valve the clearance and do a compression test. if it'll run ok afterwards just thrash it.
My Bio
