Author Topic: Wiring diagram AAZ  (Read 5411 times)
November 06, 2008, 11:59:58 pm
blueattack
  • 13
Wiring diagram AAZ
« on: November 06, 2008, 11:59:58 pm »
Does someone have a wiring diagram for a AAZ passat from 96 ?
Reply #1November 07, 2008, 06:48:07 am
Wiring diagram AAZ
« Reply #1 on: November 07, 2008, 06:48:07 am »
What specifically are you looking for?
Reply #2November 08, 2008, 10:24:26 am
blueattack
  • 13
Wiring diagram AAZ
« Reply #2 on: November 08, 2008, 10:24:26 am »
i'm having trouble starting (electrical trouble) , switched 12v doesn't work, but ignition switch is new , so i'm looking where the trouble is located
Reply #3November 14, 2008, 10:40:21 am
blueattack
  • 13
Wiring diagram AAZ
« Reply #3 on: November 14, 2008, 10:40:21 am »
nobody that has a solution ?
Reply #4November 14, 2008, 10:43:19 am
Wiring diagram AAZ
« Reply #4 on: November 14, 2008, 10:43:19 am »
Things like this get slow responses as you have discovered.
Have you checked all the relay's and fuses?
Reply #5November 14, 2008, 10:44:15 am
blkboostedtruck
  • 1535
Wiring diagram AAZ
« Reply #5 on: November 14, 2008, 10:44:15 am »
get a test light and start probing wires also check your grounds!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #6November 15, 2008, 10:22:21 am
blueattack
  • 13
Wiring diagram AAZ
« Reply #6 on: November 15, 2008, 10:22:21 am »
no problem for the slow responses! i have an xtra 12v wire !
I'm goiing to get a new relais monday , hopefully this wil resolve the problem , i didn't knew which relais i had to order , in the mean while i know which one,
i'll keep you guys informed !
thankx
