Removing downpipe-How difficult?
Topic: Removing downpipe-How difficult? (Read 2876 times)
November 05, 2008, 01:27:36 pm
bvolks73
November 05, 2008, 01:27:36 pm »
We were replacing the exhaust on my brother's 90 Jetta today when we discovered 2 holes in the downpipe. I'm not sure which turbo it has but there are 6 bolts holding the downpipe on and they all look really bad. I could hardly tell there were nuts on some of them they were so corroded. Are there any tricks to get them off without breaking? This is the first time I've touched a TD so I'm completely in the dark as to the easiest way to do it or the best place to take it apart. By the way I searched and didn't find anything.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
November 05, 2008, 03:32:28 pm
TurboJ
November 05, 2008, 03:32:28 pm »
It's not too difficult. The nuts and bolts should have a rust-remover treatment first (CRC or similar). The only thing that can be tricky are the C-clamps that hold the cast elbow connected to the rest of the downpipe. They can be forced off using some leverage.
Jetta II 1.6 TD 'Project 200'
November 05, 2008, 05:52:06 pm
November 05, 2008, 05:52:06 pm »
They aren't tricky with a long enough bar :mrgreen: :mrgreen: :mrgreen: :mrgreen:
I broke a bolt off in the turbo =(
Be very careful. MAKE SURE you use something like a breaker bar or better yet an inpact gun because you musnt put any lateral force on them or they will sheer off :cry:
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
November 05, 2008, 05:57:50 pm
bvolks73
November 05, 2008, 05:57:50 pm »
So the down pipe is definitely cast? Looks like welding up the holes in it is out of the question.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
November 05, 2008, 06:02:55 pm
November 05, 2008, 06:02:55 pm »
oh yeah it's cast
try uhhh
high temp JB weld?
or making a new bigger downpipe
Your friend/bro would find less turbo lag if you did that.
THROWN ROD
November 05, 2008, 06:12:30 pm
November 05, 2008, 06:12:30 pm »
I have welded cast...it's very pretty. Might take it to an exhaust shop and ask them if they could fab up something or make one from scratch.
Round 2
November 06, 2008, 02:16:12 am
bvolks73
November 06, 2008, 02:16:12 am »
We're going to try the JB Weld first. If it doesn't work I guess I'll have to try remove the downpipe and replace it. I have 3 of them on motors already out of cars so getting a replacement isn't a problem.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
November 06, 2008, 05:24:39 am
arb
November 06, 2008, 05:24:39 am »
Heat is the friend to rust - it accelerated it on the bolts. It is also your best friend for removing very rusty bolts without breaking anything. Ideally you'd use an oxyacetylene torch and get the bolt cherry red. It will unscrew like a new bolt if you do this. Next best thing is a propane torch, but you'll have to heat it for 10 minutes or so to get it HOT. This will cause expansion that will allow the bolts to come out without breaking.
The turbo gets much hotter than a plastic like JB weld can stand. You'll just be making the pre-welding job a bit harder. If you don't have high quality welder, high carbon welding rod (TIG or gas), and the skills, get someone to weld it for you that has experience with welding cast iron. If not welding correctly, it will crack even more.
I had to weld some cast iron on my project
http://www.vwdiesel.net/phpBB/viewtopic.php?t=15633&start=0
November 06, 2008, 05:38:00 am
mk2diesel
November 06, 2008, 05:38:00 am »
welding cast iron ...
preheat! then use "nickle rod" for strength or "splatter rod" to just fill in holes with an Arc welder
Migs and Tigs can weld almost anything ... quite often while still on the vehicle.
November 06, 2008, 10:32:48 am
November 06, 2008, 10:32:48 am »
Quote from: "mk2diesel"
preheat! .
2X... with a torch, or stick it in the oven. :wink:
November 06, 2008, 12:21:16 pm
November 06, 2008, 12:21:16 pm »
yeah sorry the JB was sort of a silly idea but those other options are rarely available to most people without a lot of money to spend on it (ie. pay someone to tig it for you).
could try the JB...? maybe you can get high temp JB weld?
if you guys REALLY don't care you can use hose clamps and soup/pop cans
i had pop cans and hose clamps sealing up my exhaust for ages.
THROWN ROD
Reply #11
November 06, 2008, 04:33:34 pm
bvolks73
Reply #11 on:
November 06, 2008, 04:33:34 pm »
We fixed it temporarily but plan on replacing the downpipe as soon as possible (on a weekend in a garage). Hopefully none of the studs will break off. The bottom ones are not a pretty sight. At least it's sealed and quiet for MVI.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
