Author Topic: Windage Tray Bolts  (Read 4620 times)
Reply #15November 06, 2008, 04:54:59 pm
VW Fox
  • 23
    • http://www.vwot.org/
Windage Tray Bolts
« Reply #15 on: November 06, 2008, 04:54:59 pm »
The oil pan is a factory European Passat part.  Both B1s (VW Dasher/Passat) and B2s (VW Quantum/Santana/Passat & Audi 4000/80) got aluminum oil pans as options, I believe in the "GT" models.
I've seen 3 different variants: 1-piece and 2 different styles of 3-piece (the baffling was different between the two).  They're all shaped, baffled and finned for longitudinal applications.
If trying to put the 1-piece into a VW Fox, the radiator gets in the way of the reservoir on that side.  I tried to devise a way of raising the stock radiator up to help with clearance but that didn't work.  The solution ended up being trading the 1-piece oil pan for a 3-piece, whose reservoir is smaller on that side.
I'll dig out some pictures of all the pans in the next few days.  I've seen pictures online of a factory VW oil pan like mine, but designed for transverse applications.  If I come across that on my hard drive, I'll post it too.
To stay marginally on-topic for this thread, the aluminum oil pans use the same bolts with the exception of 2, which have to be much longer.
1993 VW Passat (AAZ)
1992 VW Fox 8v (gasoline)
1980 VW Dasher 1.6TD (CY)
