Which piston ring?
Topic: Which piston ring? (Read 3105 times)
November 03, 2008, 04:40:22 pm
Mark(The Miser)UK
Which piston ring?
November 03, 2008, 04:40:22 pm »
http://www.autohausaz.com/search/product.aspx?sid=fuwm3h2vv2bw1w55bi5lqf45&makeid=800026@VW&modelid=1284780@QUANTUM%20GL%20CUSTOM%20TDI&year=1985&cid=20@Engine%20Parts,%20Seals%20%26%20Gaskets&gid=5640@Piston%20Ring%20Set
Which is best?
Which ring brand for a TD?
Goetze, Metal leve, or Grant ,
or none of the above?
The Goetze look cheap enough to export to the UK!
Mark-The-Miser-UK
November 03, 2008, 05:30:40 pm
maxfax
Which piston ring?
November 03, 2008, 05:30:40 pm »
I've used the Grant and Goetze rings in N/A diesles with excellent results.. Top line rings on the other hand have been questionable..
November 03, 2008, 06:33:16 pm
Which piston ring?
November 03, 2008, 06:33:16 pm »
arent the goetze one of the best brands for rings???
November 03, 2008, 08:13:00 pm
monomer
Which piston ring?
November 03, 2008, 08:13:00 pm »
no total-seal rings?
-1983 Rabbit LX 1.6/1.9 VNT build
Michigan Volkswagen Enthusiasts
www.michiganvw.org
November 03, 2008, 08:22:03 pm
Turbinepowered
Which piston ring?
November 03, 2008, 08:22:03 pm »
Quote from: "monomer"
AutohausAZ only carries stock and nearly-stock parts.
November 03, 2008, 09:01:01 pm
Dakotakid
Which piston ring?
November 03, 2008, 09:01:01 pm »
I am in the process of going with Goetz on a set of Mahle pistons in an N/A rebuild. Arizautohaus is who I got them from.
I am sincerely hoping for good results.
November 03, 2008, 09:09:12 pm
Which piston ring?
November 03, 2008, 09:09:12 pm »
Total Seal all the way!!!!!
Top Line NO FREAKIN WAY!!!!!
November 04, 2008, 03:49:42 am
Mark(The Miser)UK
Which piston ring?
November 04, 2008, 03:49:42 am »
Thanks for the replies guys.
I don't know much about Total Seal. A great idea, but I wonder if their quality is good too. Do they last long? [Just stabbing in the dark here, no knowledge adverse or otherwise]
Mark-The-Miser-UK
Which piston ring?
