Author Topic: 1.6 na and 1.9 AAZ parts  (Read 9116 times)
November 03, 2008, 10:01:56 am
  • 1739
« on: November 03, 2008, 10:01:56 am »
Just recently scrapped a 1.6 golf with hydralic head and a AAz 1.9. If you need anything from those types of motors, let me know what you desire. Good prices, just want to get rid of the stack.
Reply #1November 03, 2008, 12:35:24 pm
myke_w
  • 1099
« Reply #1 on: November 03, 2008, 12:35:24 pm »
I'm interested in the 1.9 head if it's in good shape
Reply #2November 06, 2008, 01:51:26 am
molgrips
  • 134
« Reply #2 on: November 06, 2008, 01:51:26 am »
Got any 1.9 injectors?  What condition are they in?
1994 Passat 1.9 TD Estate, 180k miles, running on veg oil
Reply #3November 06, 2008, 06:13:42 am
  • 1739
« Reply #3 on: November 06, 2008, 06:13:42 am »
Yes i do have, and they were working, but that doesn't mean they couldn't use a rebuild. Also if you have the number ,because  they went into a box with 2 other sets.
Reply #4November 06, 2008, 01:11:15 pm
zozep
  • 176
« Reply #4 on: November 06, 2008, 01:11:15 pm »
1.9 td down pipe ??
SOLD: 92 Jetta TD, Giles Pump set to 30 psi, MLS Head Gasket, ARP head studs, Huge eBay intercooler, blocked WG, FK suspension, 1.9L AAZ downpipe to 2.5 inch straight back.
Current: 2000 TDi, 01M :(  DG Full skid plate, Cat 2 micron Fuel Filter, Scanguage II, 4700kHIDs, DG RacePipe
Reply #5November 06, 2008, 02:31:20 pm
  • 1739
« Reply #5 on: November 06, 2008, 02:31:20 pm »
no sorry . was already broken
Reply #6November 06, 2008, 02:41:30 pm
blkboostedtruck
  • 1535
« Reply #6 on: November 06, 2008, 02:41:30 pm »
have any K14 oil return lines 1.6 or 1.9
i'm always looking for them?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #7January 08, 2009, 12:22:23 pm
74superman
« Reply #7 on: January 08, 2009, 12:22:23 pm »
I could use some injectors from the 1.6.  Let me know if you still have them.  Thanks.
Reply #8February 16, 2009, 04:57:14 pm
Alchemist
« Reply #8 on: February 16, 2009, 04:57:14 pm »
I could use an injection pump for an AAZ if it has 50 mm dia. mount.
Paul
Reply #9February 16, 2009, 08:37:12 pm
Powered by Spearco
  • 1203
« Reply #9 on: February 16, 2009, 08:37:12 pm »
Still have the serp. setup.
Bracket and pullies.
Thanks
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #10July 07, 2010, 08:03:31 am
Soot Sandwich
  • 40
Re: 1.6 na and 1.9 AAZ parts
« Reply #10 on: July 07, 2010, 08:03:31 am »
If it had AC, I need the waterpump pulley and crank pulley...
Reply #11July 07, 2010, 08:33:09 am
  • 1739
« Reply #11 on: July 07, 2010, 08:33:09 am »
Wow this ad was posted a while ago. I just looked at the date- Nov 2008. I may still have what you need, but i would need part numbers to go by.
Reply #12July 23, 2010, 11:27:22 am
avocado_tom
« Reply #12 on: July 23, 2010, 11:27:22 am »
Is there a diaphram vacuum pump on that 1.6na?  Or at least the top of one?
Reply #13July 23, 2010, 03:21:49 pm
  • 1739
« Reply #13 on: July 23, 2010, 03:21:49 pm »
Nope, sorry. If you need a vacuum pump, couldn't you just get the rotary one. No more diaphrams to change.
Reply #14July 23, 2010, 03:53:54 pm
Big Daddy Roth
  • 298
« Reply #14 on: July 23, 2010, 03:53:54 pm »
pm'd
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
