Author Topic: wastegate  (Read 3693 times)
October 29, 2008, 10:30:05 am
zozep
  • 176
wastegate
« on: October 29, 2008, 10:30:05 am »
Apparently my wastegate is broken... What are my options?
SOLD: 92 Jetta TD, Giles Pump set to 30 psi, MLS Head Gasket, ARP head studs, Huge eBay intercooler, blocked WG, FK suspension, 1.9L AAZ downpipe to 2.5 inch straight back.
Current: 2000 TDi, 01M :(  DG Full skid plate, Cat 2 micron Fuel Filter, Scanguage II, 4700kHIDs, DG RacePipe
Reply #1October 29, 2008, 10:31:44 am
arb
wastegate
« Reply #1 on: October 29, 2008, 10:31:44 am »
Open or closed ?
Reply #2October 29, 2008, 10:44:26 am
zozep
  • 176
wastegate
« Reply #2 on: October 29, 2008, 10:44:26 am »
Sorry, I'm getting frustrated.
This is a continuation of http://vwdiesel.net/phpBB/viewtopic.php?t=17001
I Was told that the wastegate is F%$#ed, lack of boost would indicate stuck open since the BOV is blocked off.
Reply #3October 29, 2008, 11:06:02 am
wastegate
« Reply #3 on: October 29, 2008, 11:06:02 am »
Remove the turbo and fix it maybe?
Reply #4October 29, 2008, 12:59:52 pm
53 willys
wastegate
« Reply #4 on: October 29, 2008, 12:59:52 pm »
sounds like the screw on the wastegate needs to be screwed down???
Reply #5October 29, 2008, 01:27:04 pm
  • 3468
    • McScrubbins Body Wash
wastegate
« Reply #5 on: October 29, 2008, 01:27:04 pm »
Quote from: "53 willys"
OK! I need to do this as well. where is this screw?
you can set the waste gate with said screw correct?
Reply #6October 29, 2008, 01:39:52 pm
wastegate
« Reply #6 on: October 29, 2008, 01:39:52 pm »
Depends on the turbo.
On the kkk turbos there is a screw in the middle of the waste gate you can clamp down to raise boost but on a T3.. If it's stuck open your going to need to take it apart I believe.
Reply #7October 29, 2008, 02:43:06 pm
  • 3468
wastegate
« Reply #7 on: October 29, 2008, 02:43:06 pm »
Is there a thread on that? I couldn't find one. (i have a t3. I don't know if its stuck open i just want to change it to 20 psi)
Reply #8October 29, 2008, 03:20:54 pm
wastegate
« Reply #8 on: October 29, 2008, 03:20:54 pm »
take the dp off (lots of penetrant) and give the wastegate dump valve some good taps to get it to close.  there is probably a good amount of buildup around it though...  maybe torch it to burn it off?
Reply #9December 29, 2008, 02:26:11 pm
jiggs
  • 41
wastegate
« Reply #9 on: December 29, 2008, 02:26:11 pm »
same problem :(
will torching it work? wont it kill the membrane that pulls the vane up?
Dark Projects...
Mecānica Auto e Performance...
Reply #10December 29, 2008, 02:38:42 pm
dillenger1
  • 777
wastegate
« Reply #10 on: December 29, 2008, 02:38:42 pm »
Quote from: "Smokey Eddy"
you need to take it apart and lap or clean the sealing surface.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #11December 29, 2008, 10:42:16 pm
  • 3468
wastegate
« Reply #11 on: December 29, 2008, 10:42:16 pm »
Quote from: "dillenger1"
I plugged it with JB weld. I took some pictures of that i think on my much anticipated 1.6td build thread
I plugged the 90 degree fitting that connects to the rubber line.
