Author Topic: MKI rabbit windshield removal, without breaking, how?  (Read 7632 times)
October 22, 2008, 02:08:41 pm
79rabbit4dr
« on: October 22, 2008, 02:08:41 pm »
anybody have a successful removal of a windshield without breaking/cracking the glass? I need to get my headliner installed into my rabbit. The rabbit I took it out of I just smashed the windshield (it was spidered already) and pulled the good stuff out.
Reply #1October 22, 2008, 02:36:26 pm
« Reply #1 on: October 22, 2008, 02:36:26 pm »
I don't remember, is the mk1 held in by a rubber gasket or is it glued in like the rest?
If glues in. Piano wire and a friend, heat up end of wire to melt it through the glue where ever you can reach. Once through you and your friend saw the glue as you pull the wire back and forth.
Clear as Mud?
Reply #2October 22, 2008, 05:00:44 pm
blkboostedtruck
  • 1535
« Reply #2 on: October 22, 2008, 05:00:44 pm »
MK1's up to 83 or 84 had rubber seals they started glue in about the second or last year of MK1's
it's best to razor knife the old seal and use new rubber because of thier water leaking problem! another words don't reuse the old seal it will leak and cause electrical problems down the road!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #3October 23, 2008, 08:28:31 am
« Reply #3 on: October 23, 2008, 08:28:31 am »
The only way I know of takes three people.  Two people laying on their backs in the front seats pushing with their feet on the upper corners of the glass as hard as they can, while the 3rd person gets ready to catch.
I'm sure the glass shops have a more sophisticated way.
Reply #4October 24, 2008, 04:08:48 pm
79rabbit4dr
« Reply #4 on: October 24, 2008, 04:08:48 pm »
Quote from: "lord_verminaard"
 :shock:  :shock:  :shock:  :shock:
hmmm... maybe i'll just end up taking into a shop. They should have the rubber for it right?
Reply #5October 24, 2008, 07:50:04 pm
79rabbit4dr
« Reply #5 on: October 24, 2008, 07:50:04 pm »
Quote from: "blkboostedtruck"
Duane
missed this one... if I cut it, it wouldn't be too hard to do with just one person. anybody know of a good online place to order the seal, or is it easier to just buy from the dealership/glass shop?
