Author Topic: HOW TO GET RID OF RUST ON PARTS AND IT WORKS!!  (Read 13395 times)
October 21, 2008, 07:41:27 pm
blkboostedtruck
  • 1535
« on: October 21, 2008, 07:41:27 pm »
check this link out! i tried it on some injector line holders and some rusty wast gate line nuts and bolts and it works great makes it look like new metal!
best to let soak in the malt vinegar ! the longer the better results like 2 days if a lot of rust!http://vwcaddyforum.com/showthread.php?t=17860
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #1October 21, 2008, 08:23:46 pm
VW_Commuter
  • 355
« Reply #1 on: October 21, 2008, 08:23:46 pm »
Pretty impressive.  Who would have thunk.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #2October 21, 2008, 08:25:26 pm
Turbinepowered
  • 1206
« Reply #2 on: October 21, 2008, 08:25:26 pm »
Wow.  :shock:
Time to stock up on malt vinegar...
Reply #3October 21, 2008, 08:29:16 pm
blkboostedtruck
  • 1535
« Reply #3 on: October 21, 2008, 08:29:16 pm »
i wanna try it in my sonic cleaner on some injectors and see how new it makes them? and if it speeds up the process?
it does give it that new metalic look like in the pics! unbelievable !!
Duane :shock:
'66 variant 1500S
Reply #4October 21, 2008, 08:38:56 pm
Turbinepowered
  • 1206
« Reply #4 on: October 21, 2008, 08:38:56 pm »
Quote from: "blkboostedtruck"
Duane :shock:
What kind/brand of sonic cleaner do you have? Just curious, looking at picking up one for myself.
Reply #5October 21, 2008, 08:45:26 pm
blkboostedtruck
  • 1535
« Reply #5 on: October 21, 2008, 08:45:26 pm »
it's a harbor freight special! small about 32oz good for cleaning the ol'ladys jewelry! once a week i'm her jeweler too  :D !
Duane
'66 variant 1500S
Reply #6October 21, 2008, 08:59:32 pm
rallydiesel
  • 1880
« Reply #6 on: October 21, 2008, 08:59:32 pm »
Wow. I wonder if white vinegar works aw well. I don't think I've ever seen malt vinegar in any store I've been to.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #7October 21, 2008, 09:02:19 pm
blkboostedtruck
  • 1535
« Reply #7 on: October 21, 2008, 09:02:19 pm »
try it on some rusty parts and report back! be nice to know?
 Duane
'66 variant 1500S
Reply #8October 21, 2008, 09:19:21 pm
Turbinepowered
  • 1206
« Reply #8 on: October 21, 2008, 09:19:21 pm »
Quote from: "rallydiesel"
I've seen white vinegar in 1-2 gallon jugs locally... I imagine that it's the acid in the vinegar that's working the wonders, so white should work.
Reply #9October 21, 2008, 10:10:00 pm
cyrus #1
  • 360
« Reply #9 on: October 21, 2008, 10:10:00 pm »
That is impressive.  Maybe we should fill up our varsol tanks with malt vinegar.  :)
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #10October 21, 2008, 11:50:58 pm
MJF
  • 581
« Reply #10 on: October 21, 2008, 11:50:58 pm »
I´ve used citric acid to clean out rust. It does very good results. Test piece. Phosphoric acid would be even better. It leaves phosphate to surface, which is good contact to paint. I think POR-15 Metal ready is mostly this. Klik
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #11October 22, 2008, 12:55:35 am
  • 3468
    • McScrubbins Body Wash
« Reply #11 on: October 22, 2008, 12:55:35 am »
Wooowww
That's so cool
I'm weary to eat malt vinegar now :P
Reply #12October 22, 2008, 02:38:40 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #12 on: October 22, 2008, 02:38:40 am »
I've been told that molasses will do the same thing, albeit likely more slowly.  Guys on metalshapers.org use about 7 parts water to 1 part molasses.  Takes about a week to remove the rust.
Calvin
91 VW Golf 1.6NA 5spd
Reply #13October 22, 2008, 04:37:57 am
« Reply #13 on: October 22, 2008, 04:37:57 am »
Quote from: "Smokey Eddy"
Wooowww
That's so cool
just imagine how that will clean your arteries though  :wink:
i think this guy uses a similar product to clean out ones arteries from all the plaque (build up of minerals, especially calcium)
http://www.yourticker.com/
Reply #14October 22, 2008, 10:24:48 am
  • 3468
« Reply #14 on: October 22, 2008, 10:24:48 am »
In grade 6 i did this science experiment to see what acidic properties soda pop had so i hung a galvanized nail in sprite, coke, diet coke, root beer, and so on
I used water and vinegar as a control. After about 6 weeks there was no trace of a nail in the vinegar if i remember correctly. The worst pop was tonic water i think? or diet coke...
regular coke/rootbeer i remember was the least alarming.
