TDI Engine -General Info
Compression Test
Topic: Compression Test (Read 5209 times)
October 20, 2008, 07:38:28 pm
Justin
Compression Test
October 20, 2008, 07:38:28 pm »
I know its probably been asked before so I apoligize in advance. I want to do a compression test on my MTDI and I dont know what to expect or what is required as a recomended min.
Thanks in advance (its the early TDI and has around 30k on the engine)
later
Justin
www.archeryprostaffmi.com
October 23, 2008, 04:22:29 am
Justin
Compression Test
October 23, 2008, 04:22:29 am »
No One?? what are the compression test numbers for an IDI then?? what is the 1.9 IDI compression ratio? if they are close then I would expect the compression test numbers to be close.
later
jkeiffer
October 23, 2008, 09:23:27 am
Compression Test
October 23, 2008, 09:23:27 am »
On mine, I got 400 not too long after the rebuild. I think I had put a 3 notch gasket in to be on the safe side although a 2 was what was on it before. I had slight kiss marks on the pistons, but they were probably from when my IP bracket was loose.
October 23, 2008, 10:57:28 am
Compression Test
October 23, 2008, 10:57:28 am »
In the Bentley they say 360-450 new , 276 is the bottom limit and no more than 75 lbs between high & low. But i do remember testing TDI's that had almost 500 lbs.
October 23, 2008, 12:54:59 pm
Compression Test
October 23, 2008, 12:54:59 pm »
even with bad compression you can still get them to fire up... just need some brake parts cleaner :lol: the high compression is mainly for cold starting. you'll get some smoke if the compression is bad enough though.
October 23, 2008, 01:55:37 pm
Compression Test
October 23, 2008, 01:55:37 pm »
My idi was @ 110 110 170 120 and it ran fine if you could get it started :shock:
Compression Test
