Author Topic: EDIT: The engine bay thread  (Read 8371 times)
October 19, 2008, 02:20:29 pm
« on: October 19, 2008, 02:20:29 pm »
EDIT: Apparently I'm not good with words, at all. I'd like to see pictures of all your engine bays. Especially you guys with intercoolers and all those horrible things. And I definitly need pictures of those snazzy NAs
Thanks
Reply #1October 19, 2008, 02:27:03 pm
blkboostedtruck
  • 1535
« Reply #1 on: October 19, 2008, 02:27:03 pm »
what ? you don't know what to do with yours?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2October 19, 2008, 02:33:17 pm
« Reply #2 on: October 19, 2008, 02:33:17 pm »
I think I know what I'm doing with mine.
I just want to see some pictures or dyno sheets of these engines. A lot of them sounds pretty serious
Reply #3October 19, 2008, 02:53:01 pm
blkboostedtruck
  • 1535
« Reply #3 on: October 19, 2008, 02:53:01 pm »
why don't you jot down what you had in mind and we'll do improvements from there?
Duane
'66 variant 1500S
Reply #4October 19, 2008, 03:59:07 pm
  • 1739
« Reply #4 on: October 19, 2008, 03:59:07 pm »
I think this is what you're asking. Recently removed the 1.7 KY na from my 1990 T25 transporter. Replaced it a revamped 1.9 na industrial. As it was a stationary motor turning a water pump it never had to turn more than 3000 rpms, there fore it had a tiny 8 mm head. Had my pump guy go through the pump [which was like new inside] and shove on a 10 mm head, new seals and a vanagon governor and top. Much more power now although because my tach is not quite right [using the serp setup rather than the v-belt , with a different alternator ], it seems to want to pull higher revs, but can't confirm. I may just have to get an 11 mm !
Reply #5October 19, 2008, 04:04:58 pm
« Reply #5 on: October 19, 2008, 04:04:58 pm »
Exactly. Pictures too though please :D
Sorry I should have said in the original post not just Giles pumps but anyone who's upping their power.
My NA is just about dead and I have a TD motor sitting in the hatch. I'm almost tempted to drop it in as a TD and terrorize the neighborhood. Looking for some motivation I guess
Reply #6October 19, 2008, 07:53:30 pm
blkboostedtruck
  • 1535
« Reply #6 on: October 19, 2008, 07:53:30 pm »
i like the look of this green caddy!
notice the single wiper ! clean caddy
this guy has the baddest exhaust ever produced not just for Harleys anymore! you want pictures of air ride on a caddy Tyler?
but i actually found a pic of Tyler's truck i can't tell if it's doing a burn out or blowing a radiator hose? spy shots while it was getting body work done! :shock:
Duane
'66 variant 1500S
Reply #7October 19, 2008, 11:47:40 pm
  • 3468
    • McScrubbins Body Wash
« Reply #7 on: October 19, 2008, 11:47:40 pm »
That last caddy is actually .... augh his user name eludes me but he's on the forum and postes that pic recently haha
I want to paint my jetta that green.
or "English Racing Green"
bahahaha EDIT:
ITS YOUR CADDY! I went back to the post heehee
you're hularious Duane
Reply #8October 20, 2008, 03:40:11 am
blkboostedtruck
  • 1535
« Reply #8 on: October 20, 2008, 03:40:11 am »
yea Tyler says the same thing that i'm funny! :roll:  i don't know why? :roll:
he he!
 Duane
'66 variant 1500S
Reply #9October 20, 2008, 09:22:11 am
TedV
  • 182
« Reply #9 on: October 20, 2008, 09:22:11 am »
hmm  guess it's about time I post some more pictures of the Scirocco, or just send Giles some. Will work on it. Boost back up to 20 psi is on the list to do this week before the next autocross.  If it survives the abuse I hope to have it back on the dyno in a month.  How soon y'all want the numbers? :lol:
It puked the head gasket last spring on the dyno.   :oops:
at 3500 RPM was 100 hp and 120 ft lbs torque.  Would like to know what it has once it gets into the power band.
Reply #10October 23, 2008, 01:11:48 pm
dieselwagen
  • 85
Re: EDIT: The engine bay thread
« Reply #10 on: October 23, 2008, 01:11:48 pm »
Quote from: "burn_your_money"
Thanks
1986 golf 1.6
Reply #11October 23, 2008, 01:53:53 pm
« Reply #11 on: October 23, 2008, 01:53:53 pm »
Reply #12October 24, 2008, 11:04:23 am
TedV
  • 182
« Reply #12 on: October 24, 2008, 11:04:23 am »
Tyler,
Thanks for posting my pics up above, too busy here, ya know.  As far as efficiency of the air/water setup, I don’t have any hard numbers, but at the speeds of autocross, 30mph to 60 mph, not enough airflow for an air/air cooler it seems.  My TDi I can’t touch the pipes after a few runs and you can feel the power drop.  The 1.6TD you can put your hand on the black pipe to the intake, not so much on the silver pipe going into the A/W cooler.  With 3 to 6 runs, the water doesn’t get too hot, only slightly warm at the reservoir.
Reply #13October 24, 2008, 02:28:44 pm
giulianot
  • 146
« Reply #13 on: October 24, 2008, 02:28:44 pm »
1990 cabriolet 1.9 aaz, kkk 24/26,  Giles pump, big  2.5" intercooler,  3 " P.P. downpipe
Reply #14October 26, 2008, 05:54:46 pm
blkboostedtruck
  • 1535
« Reply #14 on: October 26, 2008, 05:54:46 pm »
here ya go Tyler here's mine
Duane
'66 variant 1500S
