Author Topic: manual trans fluid  (Read 5611 times)
October 17, 2008, 12:14:32 pm
danwithagolf
  • 43
manual trans fluid
« on: October 17, 2008, 12:14:32 pm »
i know that the vw trans use the 75w 90 syn GL-4  but can you use the same but GL-5? my work has GL-5 if not im having a hard time finding the GL-4
87 Golf n/a
Reply #1October 17, 2008, 01:31:15 pm
saurkraut
  • 904
manual trans fluid
« Reply #1 on: October 17, 2008, 01:31:15 pm »
GL5 is not the right oil.  It designed to work in differentials, and has stuff that will eat the brass syncro rings in your gear box.
You need GL4
There are others out there but you could try Redline MTL: http://www.redlineoil.com/products_gearlubricants.asp?categoryID=7
or go to a VW dealer and by their manual transmission oil.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #2October 17, 2008, 07:43:16 pm
danwithagolf
  • 43
manual trans fluid
« Reply #2 on: October 17, 2008, 07:43:16 pm »
i called a auto parts store they have royal purple that says it meets gl-5 and gl-4 can i use that? i know that red line stuff is good all try to get some of that the royal stuff is 13 bucks a liter is that good?
87 Golf n/a
Reply #3October 17, 2008, 08:11:20 pm
cyrus #1
  • 360
manual trans fluid
« Reply #3 on: October 17, 2008, 08:11:20 pm »
You can get redline at bow wow.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #4October 17, 2008, 08:32:28 pm
manual trans fluid
« Reply #4 on: October 17, 2008, 08:32:28 pm »
some people say good about royal purple and others dont say so good... redline seems to have an all around good rep though.  i think royal purple might be okay for transmissions, but i've heard some people say that you get better mileage because the oil thins out and gives less protection, but they also have this synerlec stuff (pretty much just moly from what i hear) to help lube everything up.
Reply #5October 17, 2008, 09:28:13 pm
danwithagolf
  • 43
manual trans fluid
« Reply #5 on: October 17, 2008, 09:28:13 pm »
called them back and they said 18  bucks a liter for redline all take a look around from what i hear its good stuff i think all go for that thanks guys
87 Golf n/a
Reply #6October 17, 2008, 09:39:26 pm
manual trans fluid
« Reply #6 on: October 17, 2008, 09:39:26 pm »
Quote from: "danwithagolf"
OEM synthetic oil is about that price i believe... not cheap, but lasts a lonnggg time!
Reply #7October 20, 2008, 02:27:51 pm
smutts
  • 720
    ClackClackClackClackClack
manual trans fluid
« Reply #7 on: October 20, 2008, 02:27:51 pm »
If in the UK, Redline is harder to find. But Halfrauds sell Castrol SMX or was it SMS?) synthetic, which is GL4 and improves the box loads. A weighted shift linkage from the MK3 (friendly scrappy)  fits the Mk2 in a couple of minutes and improves the shift lots too. Until some time when the poxy crownwheel rivets will say "Hi there!" :roll:
Reply #8October 20, 2008, 03:15:12 pm
manual trans fluid
« Reply #8 on: October 20, 2008, 03:15:12 pm »
I looked last night as I though I was running Redline in my trans, turns out I had 2 empty Mobile 1 bottle where I thought the Redline bottles were.  :oops:
Reply #9October 20, 2008, 04:07:30 pm
manual trans fluid
« Reply #9 on: October 20, 2008, 04:07:30 pm »
I used synchromesh by penzoil in my last 2 gear boxes
