Author Topic: DELETE ME  (Read 6696 times)
October 14, 2008, 04:50:04 pm
zagarus
  • 619
DELETE ME
« on: October 14, 2008, 04:50:04 pm »
$400 takes it.
Basically the throttle lever broke off the top of the pump when i had my accident.  I called Giles up and as long as you have a parts pump that he can use to replace the top part with the repair should only cost between 150-200$.
Pretty good deal for a 950$ pump if you ask me.
Reply #1October 15, 2008, 12:45:56 pm
rallydiesel
  • 1880
DELETE ME
« Reply #1 on: October 15, 2008, 12:45:56 pm »
Do you have a pic of the damaged area?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2October 15, 2008, 01:34:21 pm
blkboostedtruck
  • 1535
DELETE ME
« Reply #2 on: October 15, 2008, 01:34:21 pm »
what was the pump set up for? how much boost? type of turbo? gov. mod red line? when did Giles do your pump
do ya remember any of that?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #3October 15, 2008, 02:05:23 pm
zagarus
  • 619
DELETE ME
« Reply #3 on: October 15, 2008, 02:05:23 pm »
the pump was set for 25psi,  intercooled, 2.5inch straight pipe engine.   The specific redline it was tuned to im not sure but it went all the way to 5,000rpm with power ( i didnt want to go any higher just yet), turbo was a garrett T3.
and the pump was rebuilt this january, pump went in the car end of march, and car died may 3rd.
And i can get a picture up asap.
Reply #4October 15, 2008, 02:16:53 pm
zagarus
  • 619
DELETE ME
« Reply #4 on: October 15, 2008, 02:16:53 pm »
so as you can see the throttle lever broke right off the top.
God this hurts to see again.
Reply #5October 15, 2008, 03:47:55 pm
rallydiesel
  • 1880
DELETE ME
« Reply #5 on: October 15, 2008, 03:47:55 pm »
Oooooh, that really sucks. That car looked pretty sweet. Any plans to build again?
Reply #6October 15, 2008, 04:21:17 pm
DELETE ME
« Reply #6 on: October 15, 2008, 04:21:17 pm »
hmmm is there any damage to the sprocket??? if not i might buy that...
Reply #7October 15, 2008, 04:34:11 pm
  • 3468
    • McScrubbins Body Wash
DELETE ME
« Reply #7 on: October 15, 2008, 04:34:11 pm »
:cry:
If i had the cash i would in a heart beat. that's my (soon to be) set up exactly.
Reply #8October 15, 2008, 04:51:14 pm
Op-Ivy
  • 513
DELETE ME
« Reply #8 on: October 15, 2008, 04:51:14 pm »
I would drive right to your house and pick it up if I had the money Tom!
Bump for a steal of a deal!
Reply #9October 15, 2008, 05:19:10 pm
zagarus
  • 619
DELETE ME
« Reply #9 on: October 15, 2008, 05:19:10 pm »
Quote from: "jtanguay"
im not sure if there is any damage to the sprocket but i dont think there is.  i was originally going to use the fuel pump from the other engine (that im selling) to fix my Giles pump then i was going to sell the fixed Giles pump.  But i lost interest in that idea.
Reply #10October 15, 2008, 05:23:29 pm
cyrus #1
  • 360
DELETE ME
« Reply #10 on: October 15, 2008, 05:23:29 pm »
PM sent.  :D
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #11October 15, 2008, 06:23:16 pm
DELETE ME
« Reply #11 on: October 15, 2008, 06:23:16 pm »
i would just use some type of epoxy to 'glue' the piece back on...  :lol: then sell my 1.6 pump  :wink: but if the sprocket is damaged, i would imagine that there could be a problem with the shaft as well, unless the sprocket could be a 'crumple' zone and take most of the beating.
still being on the car though its hard to assess the damage to the fullest extent.
Reply #12October 15, 2008, 06:27:22 pm
blkboostedtruck
  • 1535
DELETE ME
« Reply #12 on: October 15, 2008, 06:27:22 pm »
i thought the red green fix would be in order! duct tape :shock:
Duane
'66 variant 1500S
Reply #13October 15, 2008, 08:42:46 pm
DELETE ME
« Reply #13 on: October 15, 2008, 08:42:46 pm »
Quote from: "blkboostedtruck"
Duane
in a pinch  :wink:
Reply #14October 16, 2008, 09:10:54 am
DELETE ME
« Reply #14 on: October 16, 2008, 09:10:54 am »
looking more at that thing... it'll need to be torn down and cleaned on the inside  :cry: but still not a bad deal for $400...
it could probably even be welded up...
