Author Topic: 1.6L TD Hydraulic Head  (Read 4170 times)
October 11, 2008, 08:11:18 pm
VW_Commuter
  • 355
« on: October 11, 2008, 08:11:18 pm »
Found on The Samba for $75.  Thought someone might be able to use it.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #1October 11, 2008, 08:46:54 pm
« Reply #1 on: October 11, 2008, 08:46:54 pm »
conveniently missing a precup...  :(
Reply #2October 12, 2008, 10:42:32 am
VW_Commuter
  • 355
« Reply #2 on: October 12, 2008, 10:42:32 am »
But if you had a junk head to start with, it might be worth it to try and peen a new one in.  You could always lowball him :D
Greg
Reply #3October 12, 2008, 10:51:23 am
« Reply #3 on: October 12, 2008, 10:51:23 am »
There are several sizes of precups, if this one is the same as a spare head you had then ya you could probably use it.
$75 is a good price UNLESS it needs valves/ guides etc...
End up spending $400 on a "good deal" go ahead ask me how I know...  :oops:
Reply #4October 12, 2008, 10:52:56 am
blkboostedtruck
  • 1535
« Reply #4 on: October 12, 2008, 10:52:56 am »
wish he had more pics. posted?
is it in canada or calif. ?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #5October 12, 2008, 04:09:44 pm
« Reply #5 on: October 12, 2008, 04:09:44 pm »
Quote from: "zukgod1"
that makes the prothe heads seem more reasonable... jimfoo seems to have had good results with his.
Reply #6October 12, 2008, 04:58:32 pm
VW_Commuter
  • 355
« Reply #6 on: October 12, 2008, 04:58:32 pm »
If you hit the 'Map it' button on the Samba ad it shows a location NE of Pasadena, CA.  If I had a junk head with some pre-cups I would consider giving him a low-ball offer after getting some other pics.  I can't tell if the right most cylinder surface was damaged (it may be or it could just be the cr@ppy pic) but if it isn't it might be worth it.  After downloading the pic and enlarging it there doesn't appear to be any cracks between the intake and exhaust valves on any of the cylinders.
Greg
