Author Topic: question about fuseboxes  (Read 2223 times)
October 10, 2008, 01:30:39 pm
MouseGTD
  • 110
« on: October 10, 2008, 01:30:39 pm »
i have a petrol 1987 scirocco (i've been told these run mk1 golf wiring/fuse boxes), and a 1990 golf gtd. i'm planning to put the diesel engine in the scirocco, but will the engine bay wiring loom from the golf plug and play into the scirocco's fuse box? if not is there a way around this?
Reply #1October 11, 2008, 04:37:51 pm
MouseGTD
  • 110
« Reply #1 on: October 11, 2008, 04:37:51 pm »
so no one on here has ever fitted a mk2 golf turbo diesel engine to a late spec mk1 golf?
Reply #2October 11, 2008, 04:55:22 pm
  • 3255
    • My collection of HOWTOs
« Reply #2 on: October 11, 2008, 04:55:22 pm »
The gasser Sirocco chassis is an A1 and the diesel Golf is an A2... very different chassis and very different wiring, particularly at the fuse block
My suggestion would be to ignore the factory harness anyway, since diesel wiring is so simple:
- oil pressure sensors will wire up as per the original
- the wire that used to go to the Sirocco's ignition coil now goes to the fuel stop solenoid on the injection pump
- wires to the alternator should splice together fine
- starter wires should be the same... perhaps the small ignition wire is different but it can be spliced.
Pretty much all that will be left is the glow plugs... easiest approach here is a small starter solenoid and a pushbutton on the dash... here's one approach to the stuff under the hood:
http://vincewaldon.com/index.php?option=com_content&task=view&id=30&Itemid=28
Reply #3October 13, 2008, 01:59:54 pm
MouseGTD
  • 110
« Reply #3 on: October 13, 2008, 01:59:54 pm »
cheers for that mate, but what about the wires that plug into the top of the turbo?
Reply #4October 13, 2008, 07:23:02 pm
  • 3255
« Reply #4 on: October 13, 2008, 07:23:02 pm »
You got me there... I've never seen wires into the top of a turbo on an MK2... have you got any pictures ?
Reply #5October 14, 2008, 12:11:47 pm
MouseGTD
  • 110
« Reply #5 on: October 14, 2008, 12:11:47 pm »
sorry there a bit blurry
some one has mentioned it could be to do with a water cooled turbo?
Reply #6October 14, 2008, 12:32:07 pm
Jet A
  • 125
« Reply #6 on: October 14, 2008, 12:32:07 pm »
My moneys on a pressure or temperature sender or switch for the water. Probably not nessicary to wire in, but is extra insurance to notify you of failure. You would have to find out if the switch is normally open or normally closed. Then wire it in a loop with the oil pressure light. if its a sender, you can wire it in to the stock a2 water temp sensor.
85 vw golf NA ----> 2b TD  Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
