Author Topic: worn out motor mounts, or is it  (Read 3090 times)
October 09, 2008, 08:41:30 am
James8485
  • 223
« on: October 09, 2008, 08:41:30 am »
anyways been i think getting worse over the past year, if you grab the valve cover and try to move the engine back and forth it rocks pretty good just using your hands i dont know how much play should be there?
as well when driving if i on highway and just let off gas doing 118 you can feel the motor move, like i dont do this just for the fin but if im drive and give it gas then let off then give it gas the let off you can just hear "clunk, clunk,clunk as you accel and de accel
does this cause any damage if this is what i think it is (motor mounts)
being or having some play in them?
my bro told me with the 1.6TD if they get bad you have problems putting them in certain gears, i dont have that problem but as it feels pretty loose up there i dont want to reck anything untill i can get it fixed!!!
---------James--------
Reply #1October 09, 2008, 10:44:57 am
79rabbit4dr
« Reply #1 on: October 09, 2008, 10:44:57 am »
The motor mounts should allow SOME play, how far does it move when you push on the valve cover? Like an inch, or a foot?
I bought a 81 1.6 NA and when I was underneath it checking things out I noticed that I was missing a nut on the center mount (right next to the shift linkage) and the other nut was loose and about to fall off. So I took the loose nut off and went a got a match. Put some gasket maker on the first couple threats and torqued the nuts down. I must have out of whack because now it's near impossible to find first gear so I think it will at least affect that, if not do more serious damage.
Reply #2October 09, 2008, 01:05:48 pm
« Reply #2 on: October 09, 2008, 01:05:48 pm »
Ya sounds like it's time fr new mounts.
Front one is EASY to change as is the pass rear one, the one on the trans side is a bit harder just due to the extra stuff that is in the way.
Reply #3October 09, 2008, 01:08:33 pm
« Reply #3 on: October 09, 2008, 01:08:33 pm »
pretty easy to tell if its the front.  if the car shakes when in reverse or clunks or is even hard to get into reverse then you know its the front  :wink: mine was so hard to drive in reverse.. damn thing loved shaking and rocking  :lol: put in the passat solid mount (more vibrations) but lasts forever! good mod IMO.
prothe sells some cheap mounts on his site... i wonder how long they would last, as they are damn cheap compared to dealer prices!!!
Reply #4October 09, 2008, 03:37:13 pm
James8485
  • 223
« Reply #4 on: October 09, 2008, 03:37:13 pm »
can anyone give me some sites or peoples emails that sell them for a 97 1.9TD AAZ motor please....do they sell neuprine ones i think they are called?? (stiffer)
Reply #5October 09, 2008, 04:05:20 pm
Jet A
  • 125
« Reply #5 on: October 09, 2008, 04:05:20 pm »
any clunks on small speed bumps?
checked the sturts and associated bearings and bushings?
Mine moves pretty easly by the valve cover....but im superman!
85 vw golf NA ----> 2b TD  Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
Reply #6October 09, 2008, 05:01:06 pm
« Reply #6 on: October 09, 2008, 05:01:06 pm »
Quote from: "jtanguay"
I just bought one of prothe's mounts - it looks to be about the same quality as any other motor mount I've ever bought.  Don't have it in yet but I guess time will tell.  Nothing obviously wrong with it anyhow...
Reply #7October 09, 2008, 06:26:46 pm
« Reply #7 on: October 09, 2008, 06:26:46 pm »
I've heard control arm bushings clunk when they go bad.
Reply #8October 09, 2008, 07:05:32 pm
dieselwagen
  • 85
« Reply #8 on: October 09, 2008, 07:05:32 pm »
Quote from: "rabbitman"
true statement, clunk when accelerating and when you let off the gas.
the solid rubber mk4 bushing is a nice upgrade.
jtanguay pretty much describes how to tell which motor mounts is no good.
1986 golf 1.6
