General Information
Troubleshooting
Belts & Pulleys
Topic: Belts & Pulleys (Read 6462 times)
October 09, 2008, 06:39:05 am
Krazy
User+
Belts & Pulleys
October 09, 2008, 06:39:05 am »
I can not get my crank to water pump belt to line up. I installed a new water pump (40 mm hub) and now nothing lines up. Do the make different pumps? I do not have the old one to compare with.
Jack Carr
Mt. Juliet, TN
I drive a Clatterpillar 1.6 n/a
October 09, 2008, 04:44:38 pm
Belts & Pulleys
October 09, 2008, 04:44:38 pm »
Did you use your original pulley or was one supplied with the new pump?
October 10, 2008, 07:03:15 am
Krazy
User+
Belts & Pulleys
October 10, 2008, 07:03:15 am »
I used the origonal pully. I have others but they are the same.
Jack Carr
Mt. Juliet, TN
October 10, 2008, 10:13:02 am
Dakotakid
Belts & Pulleys
October 10, 2008, 10:13:02 am »
Do you, by chance, have the pulley simply facing the wrong way???
How far off in distance (mm.)?
October 10, 2008, 02:28:26 pm
Krazy
User+
Belts & Pulleys
October 10, 2008, 02:28:26 pm »
I took pictures, but I am unable to post them.
Jack Carr
Mt. Juliet, TN
October 10, 2008, 03:11:29 pm
Belts & Pulleys
October 10, 2008, 03:11:29 pm »
Photobucket is your friend..
October 13, 2008, 05:53:10 am
Krazy
User+
Belts & Pulleys
October 13, 2008, 05:53:10 am »
This is a link for photobucket. Hope it works!
<a><img></a>
Jack Carr
Mt. Juliet, TN
October 13, 2008, 06:40:22 am
Belts & Pulleys
October 13, 2008, 06:40:22 am »
Copy the img from photobucket and paste here.
needs to have
on the back of it to work.
October 13, 2008, 07:15:37 am
Krazy
User+
Belts & Pulleys
October 13, 2008, 07:15:37 am »
Jack Carr
Mt. Juliet, TN
October 13, 2008, 07:44:44 am
Dakotakid
Belts & Pulleys
October 13, 2008, 07:44:44 am »
Wow.....Cat yelloooow!!!!! I kind of like that on a block!
It would appear as though the shaft simply wasn't pressed in as far on the rebuild??
October 13, 2008, 08:30:30 am
Belts & Pulleys
October 13, 2008, 08:30:30 am »
Isnt there supose to be 2 pullies there?
Oh wait.. That's only if you have PS.
Reply #11
October 16, 2008, 09:04:49 am
Krazy
User+
Belts & Pulleys
Reply #11 on:
October 16, 2008, 09:04:49 am »
Can anyone suggest where I can get a good German water pump?
Jack Carr
Mt. Juliet, TN
Reply #12
October 16, 2008, 09:08:08 am
blkboostedtruck
Belts & Pulleys
Reply #12 on:
October 16, 2008, 09:08:08 am »
yea i'd like to see how that whole motor looks in yellow!
post some pics!
Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
Reply #13
October 16, 2008, 10:30:52 am
Quantum TD
Belts & Pulleys
Reply #13 on:
October 16, 2008, 10:30:52 am »
Some of the newer water pumps come with a metal/rubber gasket that is notably thicker than the fiber gasket that the Rabbits used. It's not enough however, to make the pulleys run out too much, but it can make a difference of about 1/2mm.
What brand WP did you use? Did you replace the whole assembly (pump and housing), or just the pump?
Reply #14
October 16, 2008, 11:04:10 am
Belts & Pulleys
Reply #14 on:
October 16, 2008, 11:04:10 am »
it almost looks as if something is out of alignment, like on an angle.. take a pic looking at the block and down the line of the pulley's
i too like the look of cat yellow on a block
reminds me of all the tonka stuff as a kid.
General Information
Troubleshooting
Belts & Pulleys
