Author Topic: leaking coolant HELPP ASAP  (Read 3616 times)
October 08, 2008, 03:43:20 pm
mainer
  • 126
« on: October 08, 2008, 03:43:20 pm »
ok i've got a 90 jetta with a 1.6 turbo diesel (swapped in) its an earlier motor with only one oil drain on the head, MF code i beleive it is.
problem is: the T hose coming out of the back of the water pump that goes to the head and the oil cooler is leaking. someone has spliced in either a plastic or a metal fitting here (i dont think this is original)
http://germanautoparts.com/Volkswagen/Jetta/Cooling/120/1
is that the hose i need? i need to get this replaced by friday.
they dont list a hose for any other years help me out here and let me knwo what i need to do.
_________________
Asian Forum
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #1October 08, 2008, 03:50:22 pm
« Reply #1 on: October 08, 2008, 03:50:22 pm »
Looks like it but I would contact Myke on this board before you push the buy button.
http://vwdiesel.net/phpBB/profile.php?mode=viewprofile&u=798
