Author Topic: low oil light flashing  (Read 6192 times)
October 06, 2008, 07:42:56 pm
Duster 5.9
  • 96
« on: October 06, 2008, 07:42:56 pm »
why does this flash? does nothing to the rev of engine. it will go dim then come back bright.
1985 golf 1.6n/a 5 spd
 if i unhook both wires from sensors they flash if i gronud each one out it  still flashes. why? is there another warning related to this? again i don't have a 85 and later bently just the older one. i will get one though.
81 rabbit gas resting
81 rabbit cabby diesel n/a
85 jetta diesel n/a
85 golf diesel runs great
82 caddy diesel clean
82 caddy gas solid resting
and some parts cars
Reply #1October 06, 2008, 07:54:20 pm
« Reply #1 on: October 06, 2008, 07:54:20 pm »
The dynamic oil pressure system is a tad complex, no doubt.
The sensor on the head is normally closed... the one on the flange is normally open... so to completely defeat the system you need to disconnect the wire to the sensor on the head and ground the wire to the sensor on the flange.
If you search for "dynamic oil pressure" you find out all the details... here's a good one to get you started:
http://www.vwdiesel.net/phpBB/viewtopic.php?t=21&highlight=dynamic+oil+pressure
Working on a HOW-TO for this since it comes up all the time.... so many HOW-TOs, so little time.  :wink:
Reply #2October 06, 2008, 08:32:55 pm
rallydiesel
  • 1880
« Reply #2 on: October 06, 2008, 08:32:55 pm »
You may want to get an oil pressure gauge though, just in case the light is right!
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #3October 06, 2008, 08:38:06 pm
« Reply #3 on: October 06, 2008, 08:38:06 pm »
Quote from: "rallydiesel"
10X...  I shoulda mentioned that right off the start !!
Reply #4October 07, 2008, 12:06:21 pm
  • 3468
    • McScrubbins Body Wash
« Reply #4 on: October 07, 2008, 12:06:21 pm »
I'm going to put in a guage too!
sorry to jack the thread but anyone suggest a method for putting in our own oil temp gauge? use the location on the head? (is that coolant?) or the one at the filter.
ps. Vince, are all of your HOW-TO's on your site? or are they some in the works, some not up yet? 8)
Reply #5October 07, 2008, 12:09:27 pm
« Reply #5 on: October 07, 2008, 12:09:27 pm »
Vince needs to put his main page link in his sig ;)
Reply #6October 07, 2008, 12:28:18 pm
« Reply #6 on: October 07, 2008, 12:28:18 pm »
Quote from: "Smokey Eddy"
Everything that's ready for primetime is there.. I have a couple in development (the pictures take a lot of time) including:
- so you wanna add a W terminal to your alternator
- the Zen of "Flashing Light, Buzzing Buzzer"
- Poor Man's way to build a piezo timing light adapter
Quote from: "zukgod1"
Great suggestion... I'm on it.
Sorry for the divergence OP... did I mention:  highly recommend you get an oil pressure gauge and check if your lights are flashing for real ??   :wink:
Reply #7October 07, 2008, 01:48:36 pm
« Reply #7 on: October 07, 2008, 01:48:36 pm »
Quote from: "Vincent Waldon"
I'm looking forward to this one!!
Reply #8October 07, 2008, 02:57:03 pm
VW_Commuter
  • 355
« Reply #8 on: October 07, 2008, 02:57:03 pm »
Wow, me too :D
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #9October 07, 2008, 08:30:10 pm
Duster 5.9
  • 96
« Reply #9 on: October 07, 2008, 08:30:10 pm »
i did a quick check on that yesterday and on my universol gauge setup they both read 80 psi cold.
85 jetta diesel n/a
and some parts cars
Reply #10October 07, 2008, 08:30:57 pm
Duster 5.9
  • 96
« Reply #10 on: October 07, 2008, 08:30:57 pm »
mechanical universol gauge that is.
85 jetta diesel n/a
and some parts cars
Reply #11October 08, 2008, 07:21:36 pm
Duster 5.9
  • 96
« Reply #11 on: October 08, 2008, 07:21:36 pm »
i touched both wires together and it still flashes.
85 jetta diesel n/a
and some parts cars
Reply #12October 10, 2008, 08:02:53 am
91 ECO
« Reply #12 on: October 10, 2008, 08:02:53 am »
I do not have a tach so I disconnected the wire from the W terminal on the alternator (after installing an oil pressure guage).  No buzzing or flashing light.
Reply #13October 10, 2008, 08:35:26 am
« Reply #13 on: October 10, 2008, 08:35:26 am »
Quote from: "Duster 5.9"
That's good but you need to check it at the head when warm.
Even a bad engine can have good oil pressure when cold.
The cluster can cause the lights to flash as well if there is a problem with it. Are you getting a buzzing as well?
Reply #14October 10, 2008, 11:10:10 am
Duster 5.9
  • 96
« Reply #14 on: October 10, 2008, 11:10:10 am »
i know my dad said something about a buzzer, but not sure if it was this golf or the jetta. how loud is it, i don't have the best of hearing HUh? joke on me lol.
what does the buzzer have to do with it?
 i drove the car to work yesterday 10 mi each way. car ran great, stat never opened so it must not of gotten warm enough.
85 jetta diesel n/a
and some parts cars
