For Sale/Looking For
Parts for Sale/Wanted
A/C Hoses for Sanden SD 709 Compressor
Topic: A/C Hoses for Sanden SD 709 Compressor (Read 4786 times)
October 04, 2008, 11:54:22 am
Sam Johnson
October 04, 2008, 11:54:22 am »
All,
I am still looking for the two A/C pipes/hoses that connect into the back of the Sanden SD709 A/C compressor. The part numbers I have are: 253-260-701B and 253-260-708. The hole in the compressor where these fit is around 18 mm with the center hole hving a taper inside. This compressor does not have screw-on type fittings. The pipe/hose ends that fit this compressor have no threads. The pipes/hoses are held with a bracket that is attached to the back of compressor by one bolt. I have this bracket but do not have the two connector hoses.
Some members of the forum call this is the MK3/4 type connector. If you require a picture give me your email address and I will email them from my aol account where I can include pictures.
With all the people that have taken the A/C off their engines there must be someone out there that has these pieces lying around in the garage.
Thanks for any assistance or suggestions. Fortunately, I have taken so much time installing the A/C that it has cooled off in Tucson (that means less than 30 degrees C) and probably do not need A/C for my 1988 Vanagon GL with a 1.9TD engine until next spring.
Sam
Tucson, AZ
October 04, 2008, 02:44:44 pm
commuter boy
October 04, 2008, 02:44:44 pm »
Go to any junkyard and take them off a gasser VW with AC. The lengths may be a bit different but you can get them with the same single bolt clamping system.
October 04, 2008, 05:52:28 pm
Sam Johnson
post subject
October 04, 2008, 05:52:28 pm »
Commuter Boy
Thanks for the suggestion. Does it need to be around the same year as mine (1988) or is there a much wider range of years and models that used the single bolt clamping systems? I saw a picture of the older Sanden 504? and it has threaded connectors so I know years that used that model A/C compressor will not work.
Again thanks for any ideas and assistance.
Regards, Sam
Tucson, AZ
October 05, 2008, 11:43:53 pm
commuter boy
October 05, 2008, 11:43:53 pm »
My experience was from looking around for AC hoses for a '93 passat with that setup, I found them in the MK3 Golfs/Jettas.
October 09, 2008, 09:32:18 pm
Sam Johnson
Post Subject
October 09, 2008, 09:32:18 pm »
I have check out the older VWs in the wrecking yard and have not found the connectors required for the VW Sanden SD 709. With all the members that have removed A/C from their cars there must be a number of members that have these connectors stored in their garages.
Let me know if you have these available.
Regards, Sam
Tucson, AZ
