Author Topic: guages  (Read 5576 times)
October 03, 2008, 07:42:52 pm
turborabbit
  • 41
guages
« on: October 03, 2008, 07:42:52 pm »
Hey, folks, I'm new to this forum, but I love rabbit pickups! Is "caddy" the proper nomenclature?? I have 5 of them-3 diesels-2 gas. Just got my '81 back on the road again-I ringed and inserted a 1.6L turbo I found in a "T-boned" Jetta, I bought from pullapart. I stuck it in my pickup and am very pleased with the extra power. Still working on my first tank, but will check fuel economy soon. I am looking for a suitable tach for it-any ideas?? In fact it needs a full set of guages. When I put the engine in, I drove it for a week and lost the original rings to a stopped up oil intake at the pump!! Any ideas or comments will be appreciated-thanks-warren
If "the more you know, then the more you know, you don't know, then I've got a lot to learn, since I'm forgetting what I thought I knew!!
01Dodge TD
81 Caddy TD
84 Winnebago/Renault TD
86Jetta84GolfCaddyCaddyCaddyCaddy
Reply #1October 03, 2008, 08:18:01 pm
blkboostedtruck
  • 1535
guages
« Reply #1 on: October 03, 2008, 08:18:01 pm »
caddy yep your correct! welcome!! you should add your location in your profile! check in the FAQ section there is a write up on converting a gasser tach to work on a diesel "W" terminal alternator!
Duane
and i thought i had a lot of caddys and i even sold 3 and now have 5 left!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2October 04, 2008, 06:50:17 am
Mark(The Miser)UK
  • 1557
guages
« Reply #2 on: October 04, 2008, 06:50:17 am »
Wot a lot of Caddy's
 :shock:
Did they ever do a 4 seater caddy? :?
Mark-The-Miser-UK
Reply #3October 04, 2008, 07:17:05 am
blkboostedtruck
  • 1535
guages
« Reply #3 on: October 04, 2008, 07:17:05 am »
Quote from: "Mark(The Miser)UK"
 :shock:
no factory one's to my knowledge!
but i have seen some home built ones using 4 door jetta's or rabbits and grafting them together!
Duane
'66 variant 1500S
Reply #4October 05, 2008, 09:14:55 am
smoken u
  • 231
guages
« Reply #4 on: October 05, 2008, 09:14:55 am »
in barrie, one person decided t graph a fullsize 8' box on a 4dr jetta diesel, crating the altimate crew-cab!!
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
