Author Topic: Broken piston ring  (Read 2306 times)
October 02, 2008, 09:48:06 pm
scoop
  • 3
Broken piston ring
« on: October 02, 2008, 09:48:06 pm »
So in my eagerness to show my 9 and 6 year old boys how to put together an engine, I didn't make sure the ring compressor was down to the deck surface and the oil ring popped out and I kept "hammering" the piston thus breaking the oil ring.The ring is toast, or eight pieces of toast, and the piston and top corner of the cylinder hole are a little bunged up. The bungs in question are enough to catch a fingernail on. The question is how bad did I screw up? A few minutes with a fine rounded file and a new ring, or new piston and trip to the machine shop? Ever happen to anyone else?
88.5 Samuria, 1.6n/a w/Giles pump in the works, Acme Adapter, and bio processor under construction.
Reply #1October 02, 2008, 10:03:21 pm
Broken piston ring
« Reply #1 on: October 02, 2008, 10:03:21 pm »
Happens to everyone at least once... sometimes twice.  :cry:
If you can post pictures of the damage we might be able to render an opinion... in particular, a closeup of the piston would be helpful.
Reply #2October 03, 2008, 06:06:09 am
scoop
  • 3
Broken piston ring
« Reply #2 on: October 03, 2008, 06:06:09 am »
Would've already if 4 year old daughter hadn't killed our nice spendy camera. I realize that you could catch a fingernail on something the thickness of a dime, but these nicks would probably do no more than put a run in the ol' ladies' pantyhose. But they are nicks nonetheless and not smooth shiny metal.
Reply #3October 03, 2008, 07:17:22 am
Broken piston ring
« Reply #3 on: October 03, 2008, 07:17:22 am »
Well one thing you have going for you is the top of the cyl doesnt contact the rings except for when you install the piston. Dang near 1/2" at the top.
The bad part is I'll bet you cracked the ring land on the piston when you broke the ring.
Experiance speaking here.
