Tap & Drill For EGT Fitment 1/8 PT
Topic: Tap & Drill For EGT Fitment 1/8 PT (Read 3149 times)
October 02, 2008, 01:06:01 am
Gernster
October 02, 2008, 01:06:01 am »
Sorry to harp on, but there is a lt of expertise on this board, am I'm very grateful for your advice!
The fixing for my EGt guage, says the connector is 1/8" PT which I'm assuming is 1/8" plug tap, but Ive always been a bit confused by BSW/ INF/ UNC etc etc...
Is this what I want? and also what size drill bit do I need?
http://cgi.ebay.co.uk/Presto-1-8-BSW-Plug-Tap-Made-in-England_W0QQitemZ170231131139QQcmdZViewItem?hash=item170231131139&_trkparms=39%3A1%7C66%3A2%7C65%3A2%7C240%3A1318&_trksid=p3286.c0.m14
October 02, 2008, 03:15:11 am
dillenger1
October 02, 2008, 03:15:11 am »
You need pipe thread.that one doesnt look tapered.
1.6td in toyota pickup
10mm head ,t3 intercooled.
October 02, 2008, 03:48:05 am
Gernster
October 02, 2008, 03:48:05 am »
ah, so it does need to be tapered then?
the thread on the fitting doesnt look tapered.....
October 02, 2008, 04:29:09 am
Turbinepowered
October 02, 2008, 04:29:09 am »
Does it call for 1/8" NPT, BPT... or is it just "PT" all by itself.
NPT is the American standard National Pipe Taper, which seals better than straight threads.
October 02, 2008, 04:59:26 am
saurkraut
October 02, 2008, 04:59:26 am »
What thermocouple are you useing. The Spruce thermoucouples come in 1/8 and 1/4 NPT and some metric sizes.
aircraftspruce.com
The larger NPT taps I have do have the drill size noted right on the shank of the tap. Otherwise, its typically on the label of the package that the tap comes in.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
October 02, 2008, 12:04:05 pm
Gernster
October 02, 2008, 12:04:05 pm »
Its a cheap chineese guage Ive bought for £25, comes complete with thermocouple. Instructions just say 1/8" PT
And do you know what, now I look at it more closeley the thread DOES look tapered!
Sorry my cameras crap at closeup!
October 02, 2008, 01:04:02 pm
arb
October 02, 2008, 01:04:02 pm »
Even if the threads on the probe are not tapered, if they are PT the tap will be tapered and it will still have the same sealing effect. Also, the photo looks like a capilary probe rather than a thermo couple.
October 02, 2008, 04:04:57 pm
Jet A
October 02, 2008, 04:04:57 pm »
If your turboed, dont stick that preturbo.
Most common is NPT as mentioned before. Can be found at most hardware stores (US) for a couple of bucks. otherwise, online. or order a thread gauge.
85 vw golf NA ----> 2b TD Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
October 03, 2008, 06:24:19 am
Gernster
October 03, 2008, 06:24:19 am »
I am turbo'ed, watercooled garret T2, (1.6GTD) which is the reason why Ive bought the EGT, so i can start to wind the boost up a little and play with the fuelling.
Conflicting advice here then, so why not pre-turbo when another guys is saying it has to be pre-turbo??
October 03, 2008, 07:02:32 am
arb
October 03, 2008, 07:02:32 am »
To be sure if you don't have a thread gauge, take the probe to the hardware / tool store. Compare the threads with the 1/8" NPT tap, they should interweave perfectly. Check the diameter as well. One way is with an NPT 1/8" die for cutting the threads on the pipe.
I cut my probe pre-turbo as TIT (turbine inlet temp) is critical to the life of the turbo. You've not going to find an aircraft with turbine exit or exhaust temp.... it does not matter.
If you are concerned the probe will be ingested by the turbine (catastrophic event) get a quality probe like from Aircraft Spruce.
October 03, 2008, 07:11:50 am
53 willys
October 03, 2008, 07:11:50 am »
go pre turbo.....I have NEVER heard of anybody having a probe break off or rust off...highly unlikely.....post turbo does not give very accurate temps.
Reply #11
October 04, 2008, 11:53:51 am
Gernster
Reply #11 on:
October 04, 2008, 11:53:51 am »
done the job, 1/8" NPT tap, £10 from a local engineering shop plus a fiver for the 11/32 drill bit.
stuck it out on number 4 next becuase I was worried about of fouling stuff.
Nice easy job, no dramas.
Should have the engine back together tomorrow so hopefull back on the road!
thanks for the help guys.
