Author Topic: Can someone post pics showing and ECO and an LDA pump? (pic)  (Read 4901 times)
Reply #15October 03, 2008, 04:41:02 am
« Reply #15 on: October 03, 2008, 04:41:02 am »
That is a true TD 1.9 pump. As Andrew said, you have a "joke" pin in that there is only a very small difference between on and off boost fueling. It is not a eco diesel though
Take the top number, it will start with 0 460 xyx xxx The y is the plunger size. 8 = 8mm, 9 = 9mm 0 = 10 mm etc. Yours should be a 9
That pump should have T30s, not flat screws holding the top cover on
Reply #16October 03, 2008, 02:31:10 pm
allsierra123
« Reply #16 on: October 03, 2008, 02:31:10 pm »
Is the pin upgradeable, Well the whole pump for that matter?
Reply #17October 03, 2008, 03:46:24 pm
« Reply #17 on: October 03, 2008, 03:46:24 pm »
If you want an all out pump, with all the tricks, send it to Giles.
If you want some more go on the cheap, check the FAQ for the "make your 1.9 a faster car"
Reply #18October 03, 2008, 04:16:47 pm
allsierra123
« Reply #18 on: October 03, 2008, 04:16:47 pm »
Good to know so I need to locate the top end of a 1.6 TD pump.
