TDI Engine -General Info
95 GTI VR6 to AHU TDI conversion
Topic: 95 GTI VR6 to AHU TDI conversion (Read 4962 times)
September 30, 2008, 07:54:15 pm
quietmission
September 30, 2008, 07:54:15 pm »
Originally, I wanted to do a toyota 4x4 truck but i never got around to it. Just bought a 95 VR6 that will eventually get a mTDI swap but I already have the mtdi pump that i bought from another member here and also i have a mechanical setup VNT20 done by Tintin. Engine block and head is sitting at rebuilder and it's from a 97 Passat tdi.
"Let it keep on ticking"
September 30, 2008, 08:02:12 pm
blkboostedtruck
September 30, 2008, 08:02:12 pm »
i'm suprised that allready has rust on the rear hatch looks more like ocean rott!
when i lived out in calif the cars near the ocean rusted from the top down! then here in wisconsin they rust from the bottom up! witch TDI motor are ya gonna use?
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
September 30, 2008, 08:33:18 pm
quietmission
September 30, 2008, 08:33:18 pm »
I expected it to be worst when i went to look at it. It does not seem that bad with the rust.
In any case, i got it for less than 1k
with some clutch or slave cylinder problem. The clutch pedal does not release back up when depressed sometimes. Right now, i just want to stuff that tdi in it and slowly get going to make it look better.
November 08, 2008, 07:36:18 am
quietmission
November 08, 2008, 07:36:18 am »
Quick updates: 1) I have included some progress pics.
2) Also, i am doing a full electronics instead of the mtdi. I will save the pump for a sidekick conversion or something else. I ended up getting a 98 jetta tdi part car and that's why i want to go electronics.
November 15, 2008, 09:02:34 am
quietmission
November 15, 2008, 09:02:34 am »
Progress pics.
[img]
November 20, 2008, 05:50:03 pm
quietmission
November 20, 2008, 05:50:03 pm »
More pics of finished product
November 20, 2008, 06:07:46 pm
November 20, 2008, 06:07:46 pm »
do you have it running?
November 21, 2008, 04:00:56 pm
quietmission
November 21, 2008, 04:00:56 pm »
Yeah, it's running but the check engine light on, runs rough and smokes cold (code 01050? glow plug monitoring) but glow plugs ohm check good.
Any help would be appreciated?
November 21, 2008, 07:16:04 pm
spencebm
November 21, 2008, 07:16:04 pm »
ill help you out by telling you to rip that VR6 symbol out of the grill and running over it a few times :twisted:
Ben Spencer
November 27, 2008, 09:22:49 am
quietmission
November 27, 2008, 09:22:49 am »
I will do just that. I want a badgeless grill and the votex dual lights.
