Author Topic: A/C Connector Pipes  (Read 4016 times)
September 30, 2008, 05:37:53 pm
Sam Johnson
  • 55
A/C Connector Pipes
« on: September 30, 2008, 05:37:53 pm »
I need to buy the two metal pipes/hoses that connect to the Sanden SD709 Compressor.  This is for a 1988 VW Vanagon GL and the part numbers are:
253-260-701B and 253-260-708
As I have converted my Vanagon to a 1.9TD the original hoses have to be modified but I need the two connectors for the rebuilt Sanden compressor I am installing.
Thanks for any assistance or suggestions
Sam
Tucson, AZ
Reply #1September 30, 2008, 06:40:23 pm
blkboostedtruck
  • 1535
A/C Connector Pipes
« Reply #1 on: September 30, 2008, 06:40:23 pm »
if you can post a pic of what compressor that would give me a better idea of witch one's you want i have a few here? from other models
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2October 01, 2008, 10:15:34 am
Sam Johnson
  • 55
Post Subject
« Reply #2 on: October 01, 2008, 10:15:34 am »
Duane,
Sorry, I took a few pictures but have not learned how to post pictures to this site.   Anyway, if you look at Go Westy Part # 253-260-797A you will see the Sanden SD709 AC compressor.  Note the text below:  This compressor does not have screw-on type fittings.  The hose ends that fit this compressor have no threads.  The hoses are held with a bracket that is attached to the back of compressor by one bolt.
I have this bracket but do not have the two connector hoses.
If you still need some pictures send me your email address and I will email them from my aol account where I can include the pictures.
Thanks for your response.
Sam
Tucson, AZ
Reply #3October 01, 2008, 10:18:42 am
A/C Connector Pipes
« Reply #3 on: October 01, 2008, 10:18:42 am »
so thats the mk3/4 style then.  the mk2 is the screw on type fittings.
you might find that you need to 'splice' the compressor end to the vanagon pipes though.  a little brazing and then clean the pipes VERY well to make sure no crap is in the system.
Reply #4October 01, 2008, 10:43:27 am
blkboostedtruck
  • 1535
A/C Connector Pipes
« Reply #4 on: October 01, 2008, 10:43:27 am »
yea sorry all i got is the MK2 style i thought i had a newer style?
Duane
'66 variant 1500S
