Author Topic: My 1.6TD/1.9 head build Thread.  (Read 2749 times)
September 29, 2008, 02:33:19 pm
monomer
  • 414
« on: September 29, 2008, 02:33:19 pm »
Stats:
- .020 overbored Turbo pistons (ceramic topped)
- Glyco Main bearings
- Total seal ring set
- 1.9 Hydro head
- Poly engine mounts
- Spec Stage 3 Clutch kit
- Full ARP stud/bolt kit (mains/head studs, con rod bolts)
- VW oil squirters
- Wastech EGT gauge/probe
- VDO boost, oil pressure/temp and coolant temp gauges
- Instrument cluster out of a gasser (w/tach) (still researching on howto use this)
- Techtronics short-shift arm; new shifter bushing/linkages (maybe a USRT kit instead)
Turbo setup:
- Mercedes t3 (off of a 92 300d) (this may change)
- T3 flanged exhaust manifold
- TiAL 38mm External wastegate
- Stock Subaru STI intercooler (I dont know it I want to try top-mounting this)
Injection:
- Giles turbo pump, rebuilt injects (per giles recommendation)
- Walbro FBR-11 lift pump
- Styadyne filtering
This is getting dropped in my nearly rust-free 1983 VW Rabbit. Comments/suggestion welcome. I'll keep adding stuff as questions comeup
www.michiganvw.org
Reply #1September 29, 2008, 03:05:27 pm
gigaz2
  • 626
« Reply #1 on: September 29, 2008, 03:05:27 pm »
lift pump might rise your IP internal pressure, you don't want that in a IDI as it screws up the dynamic timing.
how will you control the IP intake pressure? it works on "vacuum" in stock form
also, is that cluch designed with diesel in mind?
Reply #2September 29, 2008, 03:30:47 pm
monomer
  • 414
« Reply #2 on: September 29, 2008, 03:30:47 pm »
Quote from: "gigaz2"
I've read the Pumps do not cavitate easily. This pump operates at low PSI and automatically adjusts flow to demand. This pump is designed for this application, as the IP will not pull enough fuel on it's own during high boost periods.
The clutch is designed for diesel. Ordered from 034 motorsports. 6 Puck with carbon friction surfaces.
www.michiganvw.org
Reply #3September 29, 2008, 11:43:29 pm
  • 3468
    • McScrubbins Body Wash
« Reply #3 on: September 29, 2008, 11:43:29 pm »
OH THANK YOU! IM DOING THE SAME!
Yesssss someone who knows what they are doing!
Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you!
Reply #4September 30, 2008, 06:35:27 pm
monomer
  • 414
« Reply #4 on: September 30, 2008, 06:35:27 pm »
I still have a lot of questions myself.
I have no idea what I'm doing as far as intake manifolds go.
I need to look into everything required for this head swap, and possibly o-ringing this head.
www.michiganvw.org
Reply #5October 02, 2008, 04:17:58 pm
Jet A
  • 125
« Reply #5 on: October 02, 2008, 04:17:58 pm »
Get one of those regulators for the pump. screw it down to 4-7psi and let it rip.
Install it before the filter, which will help drop pressure, and prevent entrained air.
85 vw golf NA ----> 2b TD  Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
Reply #6October 02, 2008, 04:39:57 pm
subsonic
  • 1836
« Reply #6 on: October 02, 2008, 04:39:57 pm »
What are your questions re the intake?  O-ringing  has been done in the past on a aaz by andy2.  Remember, you will need to go around the prechambers.
Reply #7October 02, 2008, 07:05:40 pm
« Reply #7 on: October 02, 2008, 07:05:40 pm »
i think what dave was saying, is that if u have good flow with a ported head and a good intake and exhaust manifold, that it helps to keep the head from lifting, along with not having high boost at low rpms, that was the problem with andys car, he had that little turbo or what ever.
Reply #8October 04, 2008, 12:07:53 pm
  • 3468
« Reply #8 on: October 04, 2008, 12:07:53 pm »
I'm going to be runing a TDI intake that goes to my intercooler. the 1.6 intake doesn't fit on the 1.9aaz head i've been told but a TDI one will. but if you go that route you have to do your own plumbing to the turbo.
