Author Topic: *SOLD* FS: 1.9 m-TDI 0-miles *SOLD*  (Read 9698 times)
September 20, 2008, 04:45:33 pm
ezekiel
  • 147
« on: September 20, 2008, 04:45:33 pm »
SOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLD
Selling the TDI engine I've been working on for about 2 years now.
It WAS a 1.9 AAZ TD, it was converted to TDI when I couldn't find oversized TD pistons, but could easily find ALH pistons.
I'm going to try and list everything I can remember off the top of my head:
-Neural brand .5over AHL pistons.
-Rods were cleaned, checked, and new bushings put in
-crank was checked and polished
-new crank and rod bearings (kolbenschmidt, 6 piece mains)
-rebuilt TDI head (from the dude on TDIclub, the head is beautiful)
-all the gaskets have been replaced
-new pan with metal baffle/scraper gasket
-new timing belt, tensioner, and crank gear
-TDI injectors w/ Sprint 520s
-new oil pump
-Valve cover and proper injection lines are in my possession
iffy things:
-AAZ pump is unknown condition, bought it off eBay, never ran it on anything, also needs to be modified to TDIm, but I have a Cummins 4B pump to go with it, so you can pull the camplate from that. Also have a new 11mm pump head to put on too
-crank nose is obviously AAZ, but it is in good un-wobbled condition, it has a new bolt, properly torqued, so unless you're putting A/C on it, you will have zero problems, and even if you do put A/C on it, you probably won't have problems still.
-no turbo
-no intake manifold (I can include the G60 manifold I have, though, but the ports will need to be opened up)
-because it's an AAZ block and crank, it doesn't have the TDI crank sensor, therefor it cannot be used as a TDI unless you add an external crank angle sensor.
Asking $1200
Transmission is SOLD
thanks
will ship freight at buyers expense, local pickup obviously preferred.
reply here, PM, or email xerography11 [at] yahoo [dot] com
--Justin
Reply #1September 20, 2008, 04:51:26 pm
ezekiel
  • 147
« Reply #1 on: September 20, 2008, 04:51:26 pm »
I also have a CTN 02A transmission that I'm willing to sell, can work out a price for both if interested.
Reply #2September 20, 2008, 05:27:18 pm
RabbitGTDguy
  • 1274
« Reply #2 on: September 20, 2008, 05:27:18 pm »
This is a good deal for someone looking for a motor rebuilt with GOOD quality parts. I can tell you that the parts add up in price but that they are worth the piece of mind! *can attest to that with the mk1 mTDI build and the current b3 build*.
Someone will snag this....
Fuslit on here may have the misc. pieces someone needs to finish this as he has a 1z/AHU motor that he is going to go ahead and part out. Parts like the valve cover, an oil pump...even a true 1z/AHU crank....he would have those if someone wanted to buy them to finish this off with TDI parts
Joe
1972 VW Westfalia
Reply #3September 22, 2008, 05:00:18 pm
ezekiel
  • 147
« Reply #3 on: September 22, 2008, 05:00:18 pm »
bump  8)
Reply #4November 15, 2008, 10:32:24 am
ezekiel
  • 147
« Reply #4 on: November 15, 2008, 10:32:24 am »
price dropped to $1500
now includes the CTN Transmission
and made some edits that are in italics
new oil pump
proper injector lines
valve cover
thanks!
--Justin
Reply #5November 15, 2008, 10:43:14 am
« Reply #5 on: November 15, 2008, 10:43:14 am »
if anyones thinking of getting an m-TDI, this is the way to go... deals like this just don't come up very often, and i'm sure he has well over $1500 into this!!!
i have well into $3500+ into mine, and thats without a transmission!!!
Reply #6November 15, 2008, 01:25:04 pm
« Reply #6 on: November 15, 2008, 01:25:04 pm »
I wish you were closer....
Reply #7November 15, 2008, 01:29:28 pm
rallydiesel
  • 1880
« Reply #7 on: November 15, 2008, 01:29:28 pm »
Very good deal.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #8November 15, 2008, 02:08:15 pm
ezekiel
  • 147
« Reply #8 on: November 15, 2008, 02:08:15 pm »
Quote from: "burn_your_money"
I know it wouldn't make it that much easier as far as cost, but I've got friends in Canadia that I'd be willing to drive the 3 hours to see, and could freight it while in Canadia, so the border wouldn't have to be dealt with
but it'd still be Vancity to Ontario.   :x
Reply #9February 21, 2009, 02:50:28 pm
ezekiel
  • 147
« Reply #9 on: February 21, 2009, 02:50:28 pm »
I'm listing this again since I can't think of any use for it anymore.  I can't even get my 1.6TD to run  :roll:
As such, I've dropped the price again, I know the economy blows, but maybe someone is in the market.
 :D
--Justin
Reply #10February 21, 2009, 04:35:25 pm
Luckypabst
  • 502
« Reply #10 on: February 21, 2009, 04:35:25 pm »
Could you get an estimate to haul the thing to SoCal, either 92627 or 93545?
Thanks
Chris
'82 TD Westy
'81 NA Caddy
Reply #11February 21, 2009, 08:09:03 pm
ezekiel
  • 147
« Reply #11 on: February 21, 2009, 08:09:03 pm »
I'll figure that stuff out and leave the office lady at my work an email to see if she can get me a quote.
Can it be shipped to somewhere with a forklift or loading dock?
Reply #12February 22, 2009, 06:57:08 am
patracy
  • 142
« Reply #12 on: February 22, 2009, 06:57:08 am »
Could I get a quote as well shipped to 30339.  Commercial loading dock.
Edit: without the transmission.
Reply #13February 22, 2009, 10:50:01 am
ezekiel
  • 147
« Reply #13 on: February 22, 2009, 10:50:01 am »
I just checked vwmotors on eBay to see what they charge for freight, the 1.6td in my caddy came from them.
They are charging $350-450 to the lower 48.  Plus $100 if it's residential.
I'm going to say $350 to CA if it's to a place with a forklift.
$400 to Georgia.
That should cover making the pallet as well.
If it's less I'll refund the difference, if it's more I'll eat the difference.
--Justin
Reply #14February 22, 2009, 12:00:54 pm
« Reply #14 on: February 22, 2009, 12:00:54 pm »
i believe i have the original aaz head from this motor
