Author Topic: Wanna Buy: Mkii Tached dash cluster, km/h  (Read 3800 times)
September 19, 2008, 12:28:02 am
FoXBoXRaCiNG
  • 92
« on: September 19, 2008, 12:28:02 am »
Is what it is! Diesel cluster obviously, Calgary Boi, lemme now whatcha got!
My cat has A.D.D :(
Reply #1September 19, 2008, 05:46:40 am
alphawerks
Diesel tach
« Reply #1 on: September 19, 2008, 05:46:40 am »
Hi,
I've got a MKII cluster that has a tach which works on a diesel. It is originaly from a gas, converted to run on the W signal. (with the govenor mod I needed more than 5k) It also has a 0 to 30 psi mechanical boost gauge where the shift light used to be, and the fuel and temp gauges in the bottom of the tach.
The wiring plug is from an early MKII, with an adapter to run with the later MKII harness.
There is no glowplug led installed, and the alt led wiring has a problem.
If your interested let me know, and make an offer. I'm driving my passat now (with the 1.6td) which is why this cluster is no longer needed.
Ryan
Reply #2September 21, 2008, 09:38:41 am
FoXBoXRaCiNG
  • 92
« Reply #2 on: September 21, 2008, 09:38:41 am »
You got PM!
My cat has A.D.D :(
Reply #3September 21, 2008, 09:02:19 pm
FoXBoXRaCiNG
  • 92
« Reply #3 on: September 21, 2008, 09:02:19 pm »
Any tips n triks to check if a cluster is hooped, or how to get the alternator W to read the 8.18v A~C?
My cat has A.D.D :(
