Author Topic: Numbers stamped on rod caps  (Read 2050 times)
September 17, 2008, 05:00:38 am
« on: September 17, 2008, 05:00:38 am »
We are rebuilding an AAZ motor and have 2 rod/piston assemblies from one engine, and 2 from another. On the rod caps, 2 are stamed "42 K3" and the other 2 are stamped 32 K5"
We used to bad bottom ends to make 1 good one, there was 4 of each number.
Are we ok to run 2 of each in the same engine?
Reply #1September 17, 2008, 07:39:21 am
  • 1739
« Reply #1 on: September 17, 2008, 07:39:21 am »
i doubt they would anything like weight, probably more production dates. [i.e. 35 th week, 1995]
Reply #2September 17, 2008, 08:14:45 am
« Reply #2 on: September 17, 2008, 08:14:45 am »
i'd say just re-use the right rod for the right cyl.  so if you take cyl 1 rod from a motor, put it into cyl 1 of the one you want to rebuild... there has to be a reason why machine shops keep everything together  :wink:
Reply #3September 17, 2008, 08:42:21 am
mdonau
  • 53
« Reply #3 on: September 17, 2008, 08:42:21 am »
check the weight...should be different
if you mix 2 sets of rods make them even
Audi 80 1,6TD:
http://rapsdb.rapsinfo.de/detail.php?id=1807
1,9l TD conversion done!
