Author Topic: break lights are stuck on GRRRRRRRRR!!!!!!!!  (Read 5647 times)
June 10, 2005, 09:36:37 pm
SMOKEYDUB
  • 630
« on: June 10, 2005, 09:36:37 pm »
I degreased the underneith of my hood to day and when i was done i looked at my car and my brake lights were stuck on! WTF! I didnt think that power washing underneith the hood would effect the tail lights. Anyways havent had time to trouble shoot myself so any ideas?
thanks
Jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #1June 11, 2005, 01:05:05 am
vwmike
  • Authorized Vendor
  • 1158
« Reply #1 on: June 11, 2005, 01:05:05 am »
What year and model?
Reply #2June 11, 2005, 09:08:30 am
greggearhead
  • 153
« Reply #2 on: June 11, 2005, 09:08:30 am »
Yeah, some years/models had an electrical pressure switch for the brake lights, and some had a trigger on the pedal.  Could be a simple swap out of the switch, or you could change to a switch that is operated off of the pedal.  I like those better.
Caddy (TD Project), Caddy 1.6D, etc etc.
  Snow Performance Water-Methanol Injection
Reply #3June 11, 2005, 11:07:55 am
SMOKEYDUB
  • 630
« Reply #3 on: June 11, 2005, 11:07:55 am »
sorry its a 86 jetta td  :D
(courtesy of GILES)
Reply #4June 11, 2005, 03:19:25 pm
dieseltech
  • 129
    • http://www.geocities.com/dean16v/Page_One.html
« Reply #4 on: June 11, 2005, 03:19:25 pm »
86 is under the dash. you will see it just above the brake pedal, pull the plug off and see if your lights go out. if so it must have been water through the fire wall. bad gromet or something, maybe the switch just decided to fail just then?
86 td jetta power everything dd (update off the road for major resto).  97tdi bare bones, DD
and a private junkyard of various other vw/audi/bmw/peugeot/volvo/toyota diesels!!!
Cummins has the worlds record for being the most efficient engine ever!!!!!
for converting fuel into noise!
Reply #5June 12, 2005, 11:32:56 am
SMOKEYDUB
  • 630
« Reply #5 on: June 12, 2005, 11:32:56 am »
for some reason the switch moved and wasnt touching the brake pedal.The switch works fin so i bent the bracket slightly.
Thanks
jeff
(courtesy of GILES)
