Author Topic: Piston grooves - Somender Singh Grooves  (Read 3841 times)
September 12, 2008, 10:38:20 am
arb
« on: September 12, 2008, 10:38:20 am »
Has anyone done grooves in the head / pistion crowns to improve combustion ? I've seen quite a bit about this in the gasser world, but nothing in ours.
http://somender-singh.com
Reply #1September 14, 2008, 05:15:48 pm
mk2diesel
  • 60
« Reply #1 on: September 14, 2008, 05:15:48 pm »
we don't have squish bands over our pistons .. the grooves would lower the compression ratio .. cause hard starting ... and burn up the pistons at higher speeds ( less mass to dissipate the heat produced under heavy load )..with  higher internal temps  ...
1.6 have swirl chambers already  .. 1.9 have them built into the pistons
Reply #2September 15, 2008, 09:01:41 am
arb
« Reply #2 on: September 15, 2008, 09:01:41 am »
I would think the squash band was directly under the pre-chamber cup.  Yes, the 23:1 would drop to maybe 22:1 but an extra pound or 2 of boost would more than make up for that. Cold starts w/ slightly less compression - pull the cold start lever most of us never use.
The guys on the Groove sites have been having great sucess, but none of them are diesel heads.
Reply #3September 15, 2008, 12:56:21 pm
  • 3468
    • McScrubbins Body Wash
« Reply #3 on: September 15, 2008, 12:56:21 pm »
I have to use my cold start to keep mine idling on more than 2 cylinders once started  :cry:
Reply #4September 16, 2008, 08:11:41 pm
silvertdi
  • 125
« Reply #4 on: September 16, 2008, 08:11:41 pm »
This grooving thing sounds like a complete scam to me.
