Author Topic: I stripped a head bolt....  (Read 4931 times)
September 11, 2008, 07:08:05 pm
Goat
  • 22
« on: September 11, 2008, 07:08:05 pm »
Yup.. it takes a lot of talent to do it, but it's good as done. Any suggestions to getting it out so I can maybe one day drive the car I've been slaving over for months?
I'm so mad I can't believe I have the composure to write this...
Reply #1September 11, 2008, 07:21:48 pm
rallydiesel
  • 1880
« Reply #1 on: September 11, 2008, 07:21:48 pm »
What do you mean "get it out"? Did you round off the head or strip the threads of the block?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2September 11, 2008, 07:58:54 pm
« Reply #2 on: September 11, 2008, 07:58:54 pm »
I rounded a head off at a junkyard one time. I gave up on the engine. Had it happened in my driveway I would have drilled the head of the bolt off and just lifted the head off as if it was stud.
Obviously you would need to be very mindful of the metal shavings
Reply #3September 11, 2008, 08:48:25 pm
kane66
  • 131
« Reply #3 on: September 11, 2008, 08:48:25 pm »
you could try an easy out it's a drill bit the spins counterclockwise. The friction of the drilling eventually leads to the bolt spinning itself out of the block. Just be careful not to break it as there very hard and almost impossible to remove if sheared off.
1985 Jetta WBE
Reply #4September 12, 2008, 12:08:15 am
  • 3468
    • McScrubbins Body Wash
« Reply #4 on: September 12, 2008, 12:08:15 am »
I like the 12pt method. I've used it before on smaller but siezed applications. I used a torques socket. post again if you don't have any luck, i can imagine how frustrating this can be.
Reply #5September 12, 2008, 04:15:38 am
Dirtrag2
  • 298
« Reply #5 on: September 12, 2008, 04:15:38 am »
if its a rounded head, you can use a nut extractor set, looks kinda like a socket but with cutting edges inside so when you turn the ratchet to loosen nut it grips the rounded nut head. I saw a post on here not long ago but can't find it now... anyway you can pick up a set at Sears ( craftsman )
good luck
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #6September 12, 2008, 05:09:15 am
« Reply #6 on: September 12, 2008, 05:09:15 am »
I did it the first time I did a head gasket, I didn't have the pt. tool and was using a torx bit that fit. I couldn't fit a bolt extractor in it. I used an air chisel to spin it out. I was nevous about damging the head, but it came right out.
Reply #7September 12, 2008, 05:53:55 am
arb
« Reply #7 on: September 12, 2008, 05:53:55 am »
I had lost my Tripple Square 12mm bit too, so I used a torq bit. I had it snap too on the 3rd bolt.
I went to Sears and if you go there, they will let you order their tripple square bit for $9.95 online from the store's PC and you don't pay shipping. It came about 3 days later. When I used it to remove all the other bolts first, then for the one I stripped, I tapped it to the bottom of the stripped bolt head with a brass hammer. This worked and it removed the bolt w/o any other tricks. The tool was unharmed and the damaged bolt was used to make an alignment stud.
No, I don't reuse these stretched head bolts on a VW again, but I'm a cheap skate so I use them for other projects ;-P
Reply #8September 12, 2008, 07:34:52 am
Goat
  • 22
« Reply #8 on: September 12, 2008, 07:34:52 am »
Yeah I stripped the head out because I used a torx bit. I was so excited to get the head off that I didn't think everything out clearly.
Arb,
 What you're saying is I should take a real triple-square bit, and hammer it down into the rounded bolt and back it out like normal? I tried the socket over the bolt method, and it works with driveshaft bolts, but not in this case... If anything else I'll try the nut extractor.
 When cracking these headbolts, is it normal to hear a sharp metal-on-metal EE-EE-EE sound? I think the previous owner may have over-tightened.
Reply #9September 12, 2008, 08:05:20 am
Slave2School
  • 531
« Reply #9 on: September 12, 2008, 08:05:20 am »
Goat that sound is normal...and not good feeling too!  My TDI and a fellow AAZ er's head did the same sound.  I think it has something to do with the VW bolts.
2002 ford focme wagon
Reply #10September 12, 2008, 09:04:30 am
arb
« Reply #10 on: September 12, 2008, 09:04:30 am »
Yes, I suggest you get a tripple square and wack it into the stripped head before you do anything more. It worked for me. You can get them at most local auto parts stores. Take one of the bolts with you.
You could use an air chissle like the others have if you want to say $10.
But, are you going to use the Cogsworth studs or the factory 12mm bolts? If you use bolts, you'll need the tripple square anyway. I didn't want to wait for the studs, so I got the bolts locally. Remember, you can't reuse them anyway as they stretch when torqued correctly ( your noise you heard when they let go)
Reply #11September 12, 2008, 09:59:54 am
« Reply #11 on: September 12, 2008, 09:59:54 am »
don't forget to loosen the bolts in the proper sequence... apparently you can actually warp the head if you don't  :shock: and yea that screetching noise seems to be normal.  i guess after a while all the oil burns off.
hope you can get it out without too much effort... one of those rounded off nut removers should work  :wink:
Reply #12September 12, 2008, 02:43:30 pm
Dirtrag2
  • 298
« Reply #12 on: September 12, 2008, 02:43:30 pm »
here is what i was talking about earlier... http://vwdiesel.net/phpBB/viewtopic.php?t=15829
...Darcy
Reply #13September 12, 2008, 04:24:31 pm
« Reply #13 on: September 12, 2008, 04:24:31 pm »
just thought i'd add that these bolts are great for use on an engine stand  :wink: they fit right into the block
Reply #14September 13, 2008, 01:31:20 am
janb
  • 167
« Reply #14 on: September 13, 2008, 01:31:20 am »
Quote from: "Dirtrag2"
Yes, drive these over the OD of the head bolt.
as previously mentioned, I also use a std 12 pt socket (not triple square) and drive it over the OD head of bolt. thus you are broaching a spline on the OD of the head.  I have to use this technique frequently on the allen head bolts on Crankshaft and WP pulleys.
The Stealth Rabbit
VW-d's are forever
