Yep, definitely a monday
Pages:
Topic: Yep, definitely a monday (Read 8544 times)
Reply #15
September 09, 2008, 07:59:56 pm
Reply #15 on:
September 09, 2008, 07:59:56 pm »
If it still turns over it's problaby fine. Even though this one looked as bad as it did Giles still had me clean it because it might have been savable. I doubt yours is anything near this bad.
Reply #16
September 10, 2008, 08:56:22 am
zozep
Reply #16 on:
September 10, 2008, 08:56:22 am »
was mine this bad?
SOLD: 92 Jetta TD, Giles Pump set to 30 psi, MLS Head Gasket, ARP head studs, Huge eBay intercooler, blocked WG, FK suspension, 1.9L AAZ downpipe to 2.5 inch straight back.
Current: 2000 TDi, 01M
DG Full skid plate, Cat 2 micron Fuel Filter, Scanguage II, 4700kHIDs, DG RacePipe
Reply #17
September 10, 2008, 09:55:33 am
Reply #17 on:
September 10, 2008, 09:55:33 am »
Quote from: "zozep"
was mine this bad?
No. Yours was a rusty POS on the outside but the inards were clean
Reply #18
September 10, 2008, 11:27:20 am
Reply #18 on:
September 10, 2008, 11:27:20 am »
i think this is a good example of why people should not store their pumps
dry
i suppose filling it with something like ATF for extended periods (or even just a few months in some cases), with ALL ports carefully blocked off, should suffice right???
i dont think many people realize that diesel does break down...
Reply #19
September 10, 2008, 02:59:31 pm
Smokey Eddy
Reply #19 on:
September 10, 2008, 02:59:31 pm »
ATF will last a very long time.
You use the same priers as me Tyler
and that weird black handled one came out of my donut in the trunk. It has a use?
Ed
THROWN ROD
Reply #20
September 10, 2008, 06:32:17 pm
Reply #20 on:
September 10, 2008, 06:32:17 pm »
I love my black screwdrivers from MK2s. I have 2 of them. One in Philips mode, one in Standard mode.
Yes if this pump had beren stored full of any fluid (Except water) it would definitly not have been in this state.
The pump was in florida so the humidity is probably what did it in so fast.
Reply #21
September 10, 2008, 07:03:10 pm
Reply #21 on:
September 10, 2008, 07:03:10 pm »
I'm thinkin' those pliers are Canadian Tire's finest ??!!! :wink:
Reply #22
September 10, 2008, 07:05:45 pm
Reply #22 on:
September 10, 2008, 07:05:45 pm »
absolutly. Only the best
Reply #23
September 10, 2008, 07:08:23 pm
Reply #23 on:
September 10, 2008, 07:08:23 pm »
I actually had to clean a pump that has been using biodiesel today. I had to acid dip it to get the biodiesel residue off the parts, and even then it only softened it and I had to brush it off.
I'll ask Giles what he recomends. I know all of our core pumps on the shelves are stored dry and they are fine on the inside (cracked 2 open today). Basically keep them away from moisture and they should be ok
Reply #24
September 11, 2008, 12:09:52 pm
Smokey Eddy
Reply #24 on:
September 11, 2008, 12:09:52 pm »
would super low viscosity oil be a good choice?
Some nice synthetic or something.
Just a thought though
Any residual oil wouldn't matter either... diesel is after all basically oil.
Ed
THROWN ROD
Reply #25
September 11, 2008, 01:22:32 pm
gigaz2
Reply #25 on:
September 11, 2008, 01:22:32 pm »
I got a set of injectors that were used on biodiesel and SVO, they reek!! plus, I had a hard time getting them clean.
moiture+(diesel, svo or biodiesel)=trouble
Pages:
