Author Topic: 81 Vw Rabbit Pickup truck/Caddy Turbo Diesel super clean...  (Read 6169 times)
September 07, 2008, 09:29:39 pm
n_tensetuning
  • 28
« on: September 07, 2008, 09:29:39 pm »
Ladies & Gents
Up for sale on EBAY!!! http://cgi.ebay.com/ebaymotors...71142  and on
http://forums.vwvortex.com/zeromodify?cmd=editpost&id=51238080
is probably one of the nicest and cleanest Diesel Rabbit Pickup truck's you'll ever find.
I am the 3rd owner of this truck.
The black carpet interior is super clean and the exterior body and engine bay is rust free.
Not only is this truck a Diesel with 174k miles, but it also features a turbo diesel 1.6 from a 1985 turbo diesel with around the same mileage.
I worked for Audi/Porsche and have years of experience with Diesels and vw swaps and did all of the maintenance, upgrades and engine swap.
Motor was always run with Shell Rotella 5w30 Synthetic Oil.
This truck will get you 50mpg and haul @ss. The motor features a Garrett stock turbo that hits 12psi (Autometer boost gauge on dash).
This truck was my daily driver for years and I can't tell you how many people have asked me if I would sell it.
The truck easily carries plywood or sheetrock 4ft x 8ft sections with no problems.
MODIFICATIONS OVER THE YEARS:
*flush cabriolet front bumper with Euro Turn Signals
*front cabriolet conversion with radiator support, 7" single round lights
*Cabriolet badgless Grill (single round lights)
*1990 GTI recaro type seats
*Autometer (boost/vacuum, Oil Pressure, & Water Temp) gauges in dash
*1.6turbo diesel swap with 5 speed tranny off 1985 jetta turbo diesel
*120volt Engine Block Oil Warmer (for winter months)
*Complete bed and lower rocker panels, including engine bay covered with Herculiner
*Scirocco 16valve 10" front rotors (cross drilled) & calipers & master cylinder
*Rear Disk Brake Conversion with (cross drilled) m3 rotors & calipers and special E-brake cables
*Custom Rear Flush Roll Pan
* Rabbit gti 84 Bolt-thru Triangle windows on doors.
*Neuspeed Front Upper Strut Bar
*Front H&R lowering Springs with RPI Equipped front Struts.
*ABD short shift linkage with Power Shift weight
*PolyEurethane bushings: (Control Arms, Steering Rack, Front strut bump stops
*FUBA roof mounted antenna.
*Polished Corrado G60 valve cover
*mk3 TDI style Serpentine Belt system: with new alternator, crank pulley, & waterpump pulley 1 belt only
*3" cone intake air filter
*Upgraded to 0/2 gauge Ground & Positive Battery Wires
* rare-------Duraliner plastic bed liner & tailgate cover
*Mk3 style Door handles
*tinted windows
*16 valve tear drop wheels
*Rabbit GTI steering wheel
I'm sure I'm forgetting more.....
NEW PARTS
*cross drilled rotors & pads all around
*battery
*tail lights
*fuel filter, stainless braided fuel lines
*rebuilt axles
*all OEM engine & transmission mounts
*fully rebuilt 1.6 turbo diesel pump
*exhaust
*all coolant hoses
*radiator
*rebuilt injectors
*headlight switch
*fuel pump relay
*shifter assembly & all linkages
*ball joints
*all wheel bearings (front & rear)
A couple of things the truck can use
*steering column bearing on inside of car near universal joint. (steering column makes a little vibration/noise from time to time
*heater blower fan (makes some squeaky sounds)from time to time (easily changed from engine side (wind cowel/windshield wiper area.
*rear backup lights switch on tranny ( sticks up sometimes leaving the rear back up lights on)
*finish up coating middle of firewall with Herculiner coating.
*body work on tailgate
Other than this the car is solid.
Must sell. Wife & I expecting baby in November & we bought a tdi jetta wagon already.
any ?'s just call 860-929-1439 or email [email protected]
Dave Mendes
81 vw caddy 1.6td
Reply #1September 08, 2008, 07:58:02 am
« Reply #1 on: September 08, 2008, 07:58:02 am »
Neither one of your links work.
Reply #2September 08, 2008, 10:58:21 am
fdnyguy
  • 499
« Reply #2 on: September 08, 2008, 10:58:21 am »
Nice truck...........
wish I had $3500.
Never forget what a "Religion of Peace" did on 9/11/01.
2015 Passat TDi. 27k
1998 Jetta 1.9TTDi 228k .
2002 F250 7.3 TD   63,000 miles. Sold.
1980 Mack CF Fire Engine. Working on it.
2007 Dodge MegaCab 5.9 Cummins. Nice, but plagued with issues
Reply #3September 08, 2008, 11:21:47 am
« Reply #3 on: September 08, 2008, 11:21:47 am »
Quote from: "zukgod1"
Looks like this is it.
Reply #4September 08, 2008, 12:21:18 pm
« Reply #4 on: September 08, 2008, 12:21:18 pm »
Man that is nice..
Reply #5September 08, 2008, 12:53:25 pm
n_tensetuning
  • 28
« Reply #5 on: September 08, 2008, 12:53:25 pm »
Sorry for the bad links
Here are the correct ones.
http://forums.vwvortex.com/zerothread?id=4017788
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320296771142
Thanks for all the kind words guys
Dave Mendes
81 vw caddy 1.6td
Reply #6September 10, 2008, 06:20:00 pm
Duster 5.9
  • 96
« Reply #6 on: September 10, 2008, 06:20:00 pm »
nice caddy wow
81 rabbit gas resting
81 rabbit cabby diesel n/a
85 jetta diesel n/a
85 golf diesel runs great
82 caddy diesel clean
82 caddy gas solid resting
and some parts cars
Reply #7October 05, 2008, 09:08:44 pm
n_tensetuning
  • 28
« Reply #7 on: October 05, 2008, 09:08:44 pm »
My apologies for the late post
Car was sold back on Sept 16th.
Thanks
Dave
81 vw caddy 1.6td
