Author Topic: Rear shocks removal!  (Read 8019 times)
September 06, 2008, 03:16:20 pm
cipo28
  • 36
« on: September 06, 2008, 03:16:20 pm »
Do I need a spring compressor tool in order to remove my rear shocks? 'cause I don't have that tool, where I can get a chip one? Any ideas? It's so frustrating when you don't have a proper tool to do the job. Thanks
'94 VW Golf GL 1.9TD/AAZ
Reply #1September 06, 2008, 04:14:27 pm
gigaz2
  • 626
« Reply #1 on: September 06, 2008, 04:14:27 pm »
no, on the rear ones you can load the car until the top is loose, unscrew the top (carefully), unload it then jack it until the springs extend fully.
then take the shocks and springs off.
be real careful, as the springs are really strong and can severely injure someone if not handled with that in mind.
also take pictures and note the order and orientation of the spacers and shims on the upper shock mount.
Reply #2September 06, 2008, 04:27:32 pm
Re: Rear shocks removal!
« Reply #2 on: September 06, 2008, 04:27:32 pm »
Quote from: "cipo28"
All you need is a 17mm wrench and socket to remove the shocks:
-jack up the rear end and remove the rear wheels
- remove the 17mm bolt and nut that hold the bottom of the shock to the trailing arm of the rear suspension
- working in the trunk, remove the three 17mm nuts that hold the assortment of washers and rubber spacers on the top of the shock
- withdraw the shock
Once you remove the shock you'll be left with one more nut (it might also be a 17) that holds down the spring retainer and then you disassemble the whole unit... no spring compressor required because of the lengh of the spring.
As the previous poster suggests... good idea to take notes or pictures so that you put all the various spacers, nuts, etc back in the right order when you put your new shocks back in.
Reply #3September 06, 2008, 06:00:10 pm
gigaz2
  • 626
« Reply #3 on: September 06, 2008, 06:00:10 pm »
I like that version, a lot simpler than mine :D
I'll try it next time
Reply #4September 06, 2008, 06:42:41 pm
cipo28
  • 36
« Reply #4 on: September 06, 2008, 06:42:41 pm »
...thank you so much guys, I looked today after a spring compressor but is much more expensive than what I payed for the shocks together...this is great that I don't need it. Thanks again!
Reply #5September 07, 2008, 11:20:26 am
clbanman
  • 705
    Cambridge, Ontario
Calvin
91 VW Golf 1.6NA 5spd
Reply #6September 08, 2008, 05:38:59 pm
cipo28
  • 36
« Reply #6 on: September 08, 2008, 05:38:59 pm »
Reply #7September 08, 2008, 06:17:15 pm
« Reply #7 on: September 08, 2008, 06:17:15 pm »
And they work just fine and are very safe.... hard to believe for 12 bucks !!
Still, it's a good idea to treat a McPherson strut like a loaded gun that could go off without notice.. in other words, point it away from you at all times !!
Reply #8September 08, 2008, 07:05:04 pm
« Reply #8 on: September 08, 2008, 07:05:04 pm »
Quote from: "Vincent Waldon"
Solid advice on both counts.
Reply #9September 30, 2008, 01:42:56 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #9 on: September 30, 2008, 01:42:56 pm »
Watch out for Boge and Sachs using normal and fine metric threads for the top mounts, this has caused me grief before.
Reply #10October 01, 2008, 05:39:56 am
saurkraut
  • 904
« Reply #10 on: October 01, 2008, 05:39:56 am »
If your car has a horizontal bolt going through the shock and the axel, have a Sawzall near by.
If they salt the roads in your local, the lower shock bolt is fused to the sleeve inside the lower shock mount with rust.  You'll have to cut the lower shock bolt on both sides of the shock to get it out.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #11October 02, 2008, 07:01:25 am
BlackTieTD
  • 1512
« Reply #11 on: October 02, 2008, 07:01:25 am »
naw shouldn't be as bad as all that. i just did the rears on my salt-driven rabbit and although the lower bolts were rusted in there good, a little PB blaster and some taps with a hammer sort that out. we have to be the road salt capital of the world here.  :x
Reply #12October 02, 2008, 08:16:24 am
saurkraut
  • 904
« Reply #12 on: October 02, 2008, 08:16:24 am »
Nos-hit, I've had to do quite a few with the sawzall.
Heat, beat, rustoff, didn't do squat.
Be prepaired
Try the lowers first.  If the come out, your in luck.  If not, find a sawzall.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #13October 02, 2008, 09:52:42 am
BlackTieTD
  • 1512
« Reply #13 on: October 02, 2008, 09:52:42 am »
you made it sound like the common procedure required a sawzall to do the job on a car with this type of bolt. i think its more of a last resort if the car has been sitting in a field or something. no need to go get a sawzall before doing rear suspension work  :? can be done with simple hand tools and a jack.
Reply #14October 02, 2008, 10:45:23 am
saurkraut
  • 904
« Reply #14 on: October 02, 2008, 10:45:23 am »
I truely hope the OP doesn't need the sawzall.
But i've seen too many daily drivers in this area that need it for a rear shock change.  I guess we get more salt than you.
Lucky us....
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
