Turboswap in an ECOdiesel (K14->K24)
Topic: Turboswap in an ECOdiesel (K14->K24) (Read 8343 times)
June 06, 2005, 03:07:42 pm
Alcaid
June 06, 2005, 03:07:42 pm »
Hi,
What do you need to put the K24 turbo from another 1.6td into my ECOdiesel (1V). Is it plain bolt on? (I don't feel comfortable boosting more than 15psi with the stock k14 turbo).
I am offcourse going to install a real TD pump if I change the turbo.
It's a '92
'03 VW Golf PD130 4Motion Highline
'10 VW Passat 1.6TDI Highline
'83 VW Jetta 1.6TD, 11mm pump, H-beam rods, girdle, fully reworked AAZ head +++ Going Compound
June 06, 2005, 03:31:17 pm
June 06, 2005, 03:31:17 pm »
i don't think you'll like the K24... it takes forever to spool up
The K14 spools so quickly
June 06, 2005, 03:36:46 pm
Alcaid
June 06, 2005, 03:36:46 pm »
Yeah, spooling is great. But what would be a reasonable max boost for the k14? Which pumps would fit? I want a pump with the LDA.
June 06, 2005, 04:37:01 pm
June 06, 2005, 04:37:01 pm »
good question. I'm guessing a good K14 should be able to produce 15 psi since the big K24 will make 20 psi or more.
as for the pumps, a 1990 should fit. Does your injection pump have the line going from the compressor housing to the top of the injection pump? I've never seen an eco diesel pic b4
June 06, 2005, 04:40:28 pm
Alcaid
June 06, 2005, 04:40:28 pm »
There is no LDA device on the pump, and therefore no line from the compressor housing.
June 06, 2005, 05:04:17 pm
QuickTD
June 06, 2005, 05:04:17 pm »
I think the K14 represents the best compromise in turbo size. The K03 is a bit small but will sustain 17 psi on a 1.9TD for a good long time. The 1Z TDI also produces 16-17 psi using a K03. The K14 is huge in comparison to the K03, I would expect it to be capable of 20psi or so reliably. The K24 can make bigger boost but as others have mentioned it takes months to spin up... I'd stick with the K14 and get an LDA equipped pump from a 1.6TD or better yet a 1.9TD. I think you'll be more than satisfied.
June 07, 2005, 06:11:37 am
fastvicar
June 07, 2005, 06:11:37 am »
Can an LDA be installed on an existing ECODiesel pump? If so, where could I source one?
1981 Rabbit 1.6L TURBO!! "The Whistle Pig"
June 07, 2005, 06:29:57 am
BlackTieTD
June 07, 2005, 06:29:57 am »
^ yes. not sure... if the junk yard had a good one that would be a score.
June 07, 2005, 01:13:39 pm
June 07, 2005, 01:13:39 pm »
well my '86 TD got wrecked, and had I known how to remove the LDA I would have... (worked great up until someone turned right in front of me...)
if you're in the oshawa area (durham region). It would have been towed to a wrecker nearby! Gone since June 1st.
June 08, 2005, 06:41:00 am
91 ECO
LDA on Eco pump
June 08, 2005, 06:41:00 am »
I have been looking into this for my ECO. Yes you can do it, but down here you can't find the LDA's to install yourself. I checked with Giles and he will do it. Also looked at another ECO with the LDA installed by Giles. Looks like good work.
June 08, 2005, 06:52:13 am
Alcaid
June 08, 2005, 06:52:13 am »
I've sendt Giles a mail about building a pump for me, but waiting for reply. Seems like he is the cheapest choice although I have to pay a lot in freight because I live in Norway.
Another thing is that I use my ECO daily, so sending the pump from my car is not an option. Have to find a used pump either here in Norway (expencive), from Germany (cheaper) or even better, one in Canada (saves on shipping). Don't think there is a TD pump modding specialist here in Norway....
Reply #11
June 10, 2005, 03:52:26 am
Rat407
Authorized Vendor
Reply #11 on:
June 10, 2005, 03:52:26 am »
Giles did my ECO pump and added the LDA. So far I have 600 miles/965k on the engine and my new refreshed pump and it is great. More power than before that is for sure. I would recommend having it done.
AMS
OIL
Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
1991 Jetta ECO TD
Reply #12
June 17, 2005, 02:33:06 am
entuzijast
Reply #12 on:
June 17, 2005, 02:33:06 am »
I also have a question...I am planning to rebuild my stock turbo (1V code) K14...But, i am in dilema..Should i rebuild it or buy a new one, for example Garrett turbo, or take o different used turbo and rebuild it...I don't plan to get a new fuel pump, because i have to pass an ECO test when i register my car every year..So i don't think that putting an LDA would make the picture better (for the ECO test)....
With that situation I wanna take out as much as I can out of turbo, like some 22-26 PSI, so I don't know if the stock turbo can handle that much pressure...I will of course make new 2.5" downpipe, and put a metal (probably copper) headgasket, maybe make a 1.7L engine out of it...
Wich turbo will be able to make up to 26 PSI safely, and still keap early spooling...
Excuse me on my bad English
Reply #13
June 17, 2005, 06:56:06 am
QuickTD
Reply #13 on:
June 17, 2005, 06:56:06 am »
If you aren't going to install an LDA equipped pump, all the boost in the world will not increase the power one bit. In fact, you will probably loose a bit of power due to pumping loss.
Boost alone will not increase the power of a diesel, power comes from fueling and you need an LDA to get it without horrible off-boost smoke.
Reply #14
June 17, 2005, 07:32:58 am
TDIMeister
Reply #14 on:
June 17, 2005, 07:32:58 am »
Alcaid, just look for a GTD pump from within Europe. Good for 80 hp with an intercooler.
