Author Topic: oil cooler question  (Read 5123 times)
September 04, 2008, 08:15:31 pm
allsierra123
oil cooler question
« on: September 04, 2008, 08:15:31 pm »
any idea where I can pick up an external oil cooler kit for an AAZ?
Reply #1September 04, 2008, 08:50:46 pm
oil cooler question
« Reply #1 on: September 04, 2008, 08:50:46 pm »
Any salvage yards around ya?
Pull one off a Turbo Saab.
They not only have the sandwich plate that has a thermostat in it but a good cooler as well.
Reply #2September 04, 2008, 08:55:45 pm
oil cooler question
« Reply #2 on: September 04, 2008, 08:55:45 pm »
Turbo Volvo's are a direct bolt-on as well.
Reply #3September 04, 2008, 08:58:33 pm
oil cooler question
« Reply #3 on: September 04, 2008, 08:58:33 pm »
That may be what I meant  :?
I cant remember now what I pulled mine off, I think it was a Saab...
It fits and seems to work but till I get a oil temp gauge I'm totally guessing..
Reply #4September 04, 2008, 09:19:24 pm
oil cooler question
« Reply #4 on: September 04, 2008, 09:19:24 pm »
Andrew: if I remember from a post a long time ago at least at one point you were running both the stock water/oil cooler *and* an additional air/oil cooler ??
Giving additional oil cooling some thought but I like how the stock water/oil helps get the oil up to operating temp quickly... if my memory above is correct I'd be interested in your experience from a plumbing perspective... somehow I can't imagine stacking two sandwich plates ??!!!!   :wink:
Reply #5September 04, 2008, 09:26:44 pm
jackbombay
  • 599
oil cooler question
« Reply #5 on: September 04, 2008, 09:26:44 pm »
Quote from: "libbybapa"
Sandwich plate:
http://www.bahnbrenner.com/vw_audi/products/1395/Mocal_Thermostatic_Sandwich_Plate_4cyl
Oil cooler:
http://store.summitracing.com/partdetail.asp?part=DER-15830&view=16383&N=700+4294924500+4294839034+4294854215+4294782875
Thermo switch:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=DER-15721&N=700+115&autoview=sku
Or adjustable thermoswitch:
http://store.summitracing.com/egnsearch.asp?N=700+115+309447&D=309447
I gotta say, the adjustable controller is the shiznit for a ton of applications.  I used it on my VNT Mercedes to control the afterrun pump for the turbo, after spending 3 times as much on a relay kit and various sensors.  They were either boiling after shut down or ran forever.  The adjustable, dialed it in right away.  Only turns on if the coolant is going to boil and shuts off right away after the turbo is cooled.  Thumbs up.
Andrew
  I have a mocal thermostatic sandwich plate, and I can't say I'm particularly impressed with its ability to stop oil flow to the cooler before the oil is up to temp, but there aren't really any other options :-/
   Anyone witha Volvo one care to comment on its ability to stop flow to the cooler when the oil is still cold?
  That adjustable temp switch is BOSS! I've looked for one before but never found one, thanks for the link!  Wooo WOOOO!!!!!
Reply #6September 04, 2008, 09:30:41 pm
oil cooler question
« Reply #6 on: September 04, 2008, 09:30:41 pm »
I just looked and mine is off a Volvo not a Saab  :oops:
AS near as I can tell it stops the oil flow through it completely when it's not warm enough to open the t stat.
Reply #7September 04, 2008, 09:35:45 pm
jackbombay
  • 599
oil cooler question
« Reply #7 on: September 04, 2008, 09:35:45 pm »
Quote from: "zukgod1"
 Did you have an oil temp gauge before and after the oil cooler install?
  My oil warms up notably slower after the oil cooler install than before, and when its cold out I have to drive it pretty hard to keep it above 190*
  Sounds like I might be hitting up some junkyards on my next roadtrip looking for some turbo volvos
   I hope the fittings are the same...
Reply #8September 04, 2008, 10:06:05 pm
allsierra123
oil cooler question
« Reply #8 on: September 04, 2008, 10:06:05 pm »
from What i just read the volvo and the saab may use the same oil cooler. SO over cooling could be a possible side effect.
Reply #9September 04, 2008, 10:24:44 pm
jackbombay
  • 599
oil cooler question
« Reply #9 on: September 04, 2008, 10:24:44 pm »
Quote from: "allsierra123"
  Not with the volvo sandwich plate it seems, I have the mocal, linked by libby earlier, which I am not all that impressed with, although tencent on thesamba has the mocal and is happy with it. Maybe mine is defective?
Reply #10September 05, 2008, 05:54:12 am
allsierra123
oil cooler question
« Reply #10 on: September 05, 2008, 05:54:12 am »
Well I dont mind a used sandwich plate. But what about a used cooler should I be worried about failure?
Reply #11September 05, 2008, 05:57:36 am
allsierra123
Reply #12September 05, 2008, 06:43:36 am
oil cooler question
« Reply #12 on: September 05, 2008, 06:43:36 am »
Wow thats funny looking!
I don't worry about over cooling with the t stat controlled sandwich plate installed.
As far as being worried about failure goes the only thing that could really fail would be the hoses, get new ones and be worry free..
I replaced one of the two hoses that came on mine but only because it wasn't long enough, I ground off the pressed collars and reused the fittings.
Reply #13September 05, 2008, 06:44:19 am
Luckypabst
  • 502
oil cooler question
« Reply #13 on: September 05, 2008, 06:44:19 am »
I fully disassembled my Volvo sandwich plate to clean and replace the O-rings. I had to put the little valve in the freezer to get it to close fully. At an ambient air temperature near 100 degrees it would remain open by about 30%.
Chris
'82 TD Westy
'81 NA Caddy
Reply #14September 05, 2008, 07:14:20 am
jackbombay
  • 599
oil cooler question
« Reply #14 on: September 05, 2008, 07:14:20 am »
Is this what your talking about but it doesnt look like a sandwich plate.
http://cgi.ebay.com/ebaymotors/VOLVO-760-TURBO-740-OIL-COOLER-SET-UP-COMPLETE-HOT-ROD_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ46098QQihZ018QQitemZ280259152276QQrdZ1QQsspagenameZWD1V
  Thats not what the one on my 240 turbo gasser looked like, the one I am thinking of actually looks quite like the mocal one.
