Author Topic: Injection line  (Read 2037 times)
September 04, 2008, 04:22:54 pm
boosted_diesel_84
  • 216
Injection line
« on: September 04, 2008, 04:22:54 pm »
anyone have a source for the formed line from the injection pump to the head? for a 85 TD. i was able to get cyl 1,2, and 4, but my part supplier was unable to get cyl 3, i called the stealership and they wanted almost $80 for it. i bought the other 3 from Foreign Automotive Parts for around $10 each. any help appreciated. thanks!
-Jack-
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #1September 04, 2008, 05:45:33 pm
gigaz2
  • 626
Injection line
« Reply #1 on: September 04, 2008, 05:45:33 pm »
068130303 for the n#3 pressure pipe, 26.6€ from VW
your not the first to be rated a lot more in the US, try a different stealer.
burst that exact one yesterday about 15Km from home.. 3cyl mode for 10km, then a long walk to get a spare and the 17mm wrench :evil:
Reply #2September 05, 2008, 03:01:36 am
Mark(The Miser)UK
  • 1557
Injection line
« Reply #2 on: September 05, 2008, 03:01:36 am »
Quote from: "gigaz2"
Where did the pipe split?
Mark-The-Miser-UK
