Author Topic: Racor CCV  (Read 6958 times)
September 04, 2008, 08:11:21 am
saurkraut
  • 904
Racor CCV
« on: September 04, 2008, 08:11:21 am »
I've been thinking about a CCV for a while.  They keep crank case gack out of your intake.
Found this Ebay auction:
ccv3500
This is the smallest CCV that Racor makes, and this auction is about 1/2 the price I've seen this same unit list for elseware.
I bought one for my '79.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #1September 04, 2008, 08:12:51 am
Duster 5.9
  • 96
Racor CCV
« Reply #1 on: September 04, 2008, 08:12:51 am »
what is it?
81 rabbit gas resting
81 rabbit cabby diesel n/a
85 jetta diesel n/a
85 golf diesel runs great
82 caddy diesel clean
82 caddy gas solid resting
and some parts cars
Reply #2September 04, 2008, 08:13:37 am
Racor CCV
« Reply #2 on: September 04, 2008, 08:13:37 am »
Quote from: "Duster 5.9"
what is it?
X 2
Reply #3September 04, 2008, 08:13:58 am
Duster 5.9
  • 96
Racor CCV
« Reply #3 on: September 04, 2008, 08:13:58 am »
what is it?
85 jetta diesel n/a
and some parts cars
Reply #4September 04, 2008, 08:23:03 am
saurkraut
  • 904
Racor CCV
« Reply #4 on: September 04, 2008, 08:23:03 am »
Jees, you guys post fast.  I was still edting the first post cause I was intending to see how the picture turned out in 'PREVIEW" and I accidently posted it.
Its a crank case breahter filter.  It takes the oil mist out of the blow by gasses and drains them back to the crank case.
Did you ever look at the tarry crap that coats the inside of your compressor.  This will filter it out of the blow by gasses and send it back to the crank case.
The $120 price compaires favorably to a decent looking catch can.
There is a flange on the block right next to the vacume pump.  Thats where I'll drain the gack back into the crank case.
I have a PDF data sheet.  How do you post those?
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #5September 04, 2008, 08:26:34 am
Duster 5.9
  • 96
Racor CCV
« Reply #5 on: September 04, 2008, 08:26:34 am »
i guess for certain applications it would help but if i had that much blowby to contend with i would spend the 120 bucks on new rings.
85 jetta diesel n/a
and some parts cars
Reply #6September 04, 2008, 08:29:08 am
Duster 5.9
  • 96
Racor CCV
« Reply #6 on: September 04, 2008, 08:29:08 am »
or is this a bigger problem with the turbo cars.
85 jetta diesel n/a
and some parts cars
Reply #7September 04, 2008, 08:31:30 am
saurkraut
  • 904
Racor CCV
« Reply #7 on: September 04, 2008, 08:31:30 am »
"Thank you mister know-it-all...."
New rings and all, there is still oil in the crank case gases, and there is blow by on every diesel on the planet.
This unit takes the gack out so you don't put it in your intercooler.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #8September 04, 2008, 08:33:27 am
saurkraut
  • 904
Racor CCV
« Reply #8 on: September 04, 2008, 08:33:27 am »
Take a clean white doiley, and wipe the crank case vent side of your airfilter, then talk to me about new rings.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #9September 04, 2008, 08:44:36 am
arb
Racor CCV
« Reply #9 on: September 04, 2008, 08:44:36 am »
I have to agree, every VW diesel I've had shows more oil blow by than I like. Even the 1.6L I blue-printed.
So, the list price was $240 ?
Reply #10September 04, 2008, 08:45:06 am
blkboostedtruck
  • 1535
Racor CCV
« Reply #10 on: September 04, 2008, 08:45:06 am »
Karl,
does it have a one way flow? or will it pressurize from either end ?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #11September 04, 2008, 09:00:41 am
saurkraut
  • 904
Racor CCV
« Reply #11 on: September 04, 2008, 09:00:41 am »
Quote from: "blkboostedtruck"
Karl,
Duane
Its a flow through device.  You connect the bottom nerple to the breather on the engine, and the top nerple to the intake.  the two teeny nerples are for draining the gack back to the mud drum.
I had the Racor tech guys Email the PDF data sheet to me befor I bought it.  So if some one can tell me how to post a PDF, I'll put 'er up.
I was just about to buy the Racor CCV4500 for a butt load more from another place when I found this Ebay auction.  Color me happy.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #12September 04, 2008, 09:23:36 am
saurkraut
  • 904
Racor CCV
« Reply #12 on: September 04, 2008, 09:23:36 am »
Here is a general PDF on Racor CCVs.  I have the 3500 specific one on my confuser. So as soon as I can figure out how to post it, I'll get that up too.
Racor CCVs
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #13September 04, 2008, 09:42:02 am
myke_w
  • 1099
Racor CCV
« Reply #13 on: September 04, 2008, 09:42:02 am »
FYI - FWIW I think the Mann Provent 200  is a better deal..
see links
http://www.airnowsupply.com/provent.htm
http://www.airnowsupply.com/catalogs/Provent%20Brochure.pdf
Not sure what they're asking but I think it's considerably less than the Racor.  Market price on thr PV was around 140 last I checked.
Reply #14September 04, 2008, 09:45:47 am
myke_w
  • 1099
Racor CCV
« Reply #14 on: September 04, 2008, 09:45:47 am »
<------ puts foot in mouth.. didn't open to OP's ebay link :(  :oops:
