Author Topic: inj pump runaway  (Read 4166 times)
September 04, 2008, 08:07:13 am
Duster 5.9
  • 96
inj pump runaway
« on: September 04, 2008, 08:07:13 am »
got a question on an injection pump. awhile back i got a rebuilt pump from a guy. i won't say where yet. anyway after alot of tuning, this thing does not like to come down in rpm when reved up sometimes. or very slowly. i took it out, but when i would drive it i would have to wait a bit with clutch in for rpm drop to engage clutch again. also had to shut it down a few times also.  i know its the pump for sure, but what? how can i fix it.
81 rabbit gas resting
81 rabbit cabby diesel n/a
85 jetta diesel n/a
85 golf diesel runs great
82 caddy diesel clean
82 caddy gas solid resting
and some parts cars
Reply #1September 04, 2008, 08:10:09 am
inj pump runaway
« Reply #1 on: September 04, 2008, 08:10:09 am »
Have you attempted any adjustments?
Throttle stop on the idle side?
Max fuel screw?
Reply #2September 04, 2008, 08:15:49 am
Duster 5.9
  • 96
inj pump runaway
« Reply #2 on: September 04, 2008, 08:15:49 am »
yes it is like what ever is inside is not coming back, but with engine off you can rev on throttle and it feels fine.
85 jetta diesel n/a
and some parts cars
Reply #3September 04, 2008, 09:08:30 am
inj pump runaway
« Reply #3 on: September 04, 2008, 09:08:30 am »
Have you attempted to reindex the throttle shaft?
Reply #4September 04, 2008, 09:43:58 am
inj pump runaway
« Reply #4 on: September 04, 2008, 09:43:58 am »
Make sure that the throttle shaft is not binding, but I would suspect that the max quantity adjuster is turned in a bit too far.
It could also be bad injectors, have those been tested?
Reply #5September 04, 2008, 10:03:18 am
Duster 5.9
  • 96
inj pump runaway
« Reply #5 on: September 04, 2008, 10:03:18 am »
i decided to send it back to where i got it from. it is for my father.
the car is driven every day with a different pump although it is majorly underpowered. meaning it is hard to keep it going 60 mph. it does smoke. i'm thinking it may need rings.
85 jetta diesel n/a
and some parts cars
Reply #6September 04, 2008, 10:28:48 am
gigaz2
  • 626
inj pump runaway
« Reply #6 on: September 04, 2008, 10:28:48 am »
bad rings and injectors(probably) and you're blaming the pump??
I also agree with the above, shaft reindexing and max fuel screw.
VW says in the manual:
try the following list before diagnosing a bad pump:
HUGE list, basically everything else  :wink:
EDIT: basically VW says that if the engine runs, pump is good, it may require some love, but its good.
Reply #7September 04, 2008, 02:29:59 pm
inj pump runaway
« Reply #7 on: September 04, 2008, 02:29:59 pm »
My car as 250 psi across the board, it NEEDS rings. I can still easily do 75 mph on the highway, and get there pretty quickly (relativly of course)
I'd suspect pump issues, timing or injectors.
You should send the pump to Giles for a super pump
Reply #8September 04, 2008, 03:09:26 pm
  • 3468
    • McScrubbins Body Wash
inj pump runaway
« Reply #8 on: September 04, 2008, 03:09:26 pm »
If you don't have $1,000 like many to send it to giles,
i'd get a timing dial on the pump and make sure the timing is set right, or even play with the timing a little bit and take it for a rip with each minor adjustment
Reply #9September 04, 2008, 06:16:00 pm
Duster 5.9
  • 96
inj pump runaway
« Reply #9 on: September 04, 2008, 06:16:00 pm »
i know that pump was not set up correctly as it made funny noises also. i even put the pump from my daily drive on this car and it ran the same. i have set the timeing many times on this car and many others. i even turned up the original pump on it to give it lots more fuel and it made 0 and i mean 0 difference.
85 jetta diesel n/a
and some parts cars
Reply #10September 04, 2008, 06:46:13 pm
4KTD
inj pump runaway
« Reply #10 on: September 04, 2008, 06:46:13 pm »
I just resealed my 1.9 pump and when I put it back on my car it does the samething.  When I rev it up it creeks up to 3000 rpm and VERY slowly comes back down and won't idle. If I index the throttle shaft to the next notch it idles at 4700 rpm... a bit high.  It does not smoke at all, I adjust the max fuel and doesn't make much difference.  I messed around with it long enough and couldn't fix it so I just bought another pump and will try it soon.
PS: the original pump was working perfectly before I resealed it, except it leaked of course.
Reply #11September 04, 2008, 06:46:40 pm
gigaz2
  • 626
inj pump runaway
« Reply #11 on: September 04, 2008, 06:46:40 pm »
so definitely not the pump :(
have you done a compression test?
bad injectors could also be the culprit as these little engines seem to work with very little compression (mines arounf 300PSI and still pulling strong)
Reply #12September 04, 2008, 06:51:24 pm
Duster 5.9
  • 96
inj pump runaway
« Reply #12 on: September 04, 2008, 06:51:24 pm »
Quote from: "gigaz2"
 no ,i have a very nice mac compression set, but i don't have that adaptor, I NEED IT! yes.
 i also would like to make that homemade pop tester when i find the time  :)  :)  :roll:
85 jetta diesel n/a
and some parts cars
Reply #13September 04, 2008, 08:57:11 pm
inj pump runaway
« Reply #13 on: September 04, 2008, 08:57:11 pm »
I tell ya what injectors will cause some weird crap to happen as well. I'm not saying that's your problem just backing up what gigaz2 said.
I just got done re ringing my engine (new pistons also) and I had this weird miss. It sounded like a Subaru with a after market exhaust system till 2000 or so where it would smooth out.
I swapped in my HUGE injectors just to see and idles smooth and runs perfect now.
Weird I say weird...
Reply #14September 05, 2008, 01:53:54 am
Duster 5.9
  • 96
inj pump runaway
« Reply #14 on: September 05, 2008, 01:53:54 am »
Quote from: "zukgod1"
subaru thats funny, i went to see my step son in tn this summer he drives one, what a wierd setup  :lol:
85 jetta diesel n/a
and some parts cars
