Author Topic: Let the Vanagon TD conversion commence!  (Read 8612 times)
Reply #15September 12, 2008, 10:23:17 pm
Powered by Spearco
  • 1203
« Reply #15 on: September 12, 2008, 10:23:17 pm »
Thats what I thought!
I pulled off the valve cover to have a look see also. The head was really clean in side there. Valve to lifter clearance is good too.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #16September 21, 2008, 06:03:51 pm
Powered by Spearco
  • 1203
« Reply #16 on: September 21, 2008, 06:03:51 pm »
Well its in. I put off any preventitive maintenance as noted before due to the turbo was filled with oil. I figured that if anythings going to happen it will.
I did get another bellhousing that was beautiful compared to the earlier post. I did put in a new clutch set though. I still need to connect some coolant hoses and do a finnal electrical tidying, and run new fuel lines and filter housing.
I did get it running today too. After priming the pump she fired right up. Belive it or not the motor sounds fairly good. No injector knocking or engine knocking. Oil pressure light went out right after it started, and no leaks as of yet. I wasn't abole to run it long due to no coolant lines hooked up yet. Ran it just long enough to hear it run. Idles good, but kind of hangs when reved up. I think because of the turbo seals?
I'll see if I can't get a video of it running.
Josh
'13 Golf R:. Tuned
'98 Puch G320
Reply #17September 21, 2008, 06:28:04 pm
Powered by Spearco
  • 1203
« Reply #17 on: September 21, 2008, 06:28:04 pm »
Yes it is. I kind of hope its a fueling issue, because the turbo is almost a solid rusted piece. The turbo was filled with oil, but before I started it ,I sucked all of the oil out as to not have it run away on me on start up.
I haven't realy reved it up high yet, gotta get coolant in it. I did find a small fuel leak at #1 injector. Maybe its not tight, don't know, its getting dark. Pretty much its set up to hear it run only.
Josh.
'13 Golf R:. Tuned
'98 Puch G320
Reply #18September 21, 2008, 06:45:32 pm
Powered by Spearco
  • 1203
'13 Golf R:. Tuned
'98 Puch G320
Reply #19December 13, 2008, 03:54:21 pm
Powered by Spearco
  • 1203
« Reply #19 on: December 13, 2008, 03:54:21 pm »
Got some gauges and a gauge console made up using fiberglass. Still needs some finnishing touches, but very happy with the turn out. What do you think?
and from the drivers seat.
'13 Golf R:. Tuned
'98 Puch G320
Reply #20December 13, 2008, 04:42:51 pm
Quantum TD
  • 1195
« Reply #20 on: December 13, 2008, 04:42:51 pm »
Pretty slick. What it that made out of? Cast aluminum?
Reply #21December 13, 2008, 04:48:55 pm
Powered by Spearco
  • 1203
« Reply #21 on: December 13, 2008, 04:48:55 pm »
How did you fasten it to the dash.
I glassed on some strips of aluminium that hang through the ash tray and then can be screwed down.
I like the fact that you put in a cup holder.
'13 Golf R:. Tuned
'98 Puch G320
Reply #22December 13, 2008, 06:57:59 pm
Quantum TD
  • 1195
« Reply #22 on: December 13, 2008, 06:57:59 pm »
Wow. Where do you find the time?
Reply #23December 13, 2008, 11:41:54 pm
allsierra123
« Reply #23 on: December 13, 2008, 11:41:54 pm »
Dang let me know if you start making those I would love to have one.
Reply #24April 24, 2009, 09:12:15 am
Powered by Spearco
  • 1203
« Reply #24 on: April 24, 2009, 09:12:15 am »
Finnally got the time to finnish the gauge pod. I flocked it with the kit from
Eastwood. It has some patchy spots, but over all I'm happy with the results.
Next is to wire it all up.
'13 Golf R:. Tuned
'98 Puch G320
Reply #25April 24, 2009, 10:02:50 am
« Reply #25 on: April 24, 2009, 10:02:50 am »
thats puuurdy :P
Reply #26April 24, 2009, 10:07:16 am
Powered by Spearco
  • 1203
« Reply #26 on: April 24, 2009, 10:07:16 am »
Thanks.  :)
'13 Golf R:. Tuned
'98 Puch G320
Reply #27April 24, 2009, 10:53:31 am
Powered by Spearco
  • 1203
« Reply #27 on: April 24, 2009, 10:53:31 am »
Yes. 100 to 1900.
'13 Golf R:. Tuned
'98 Puch G320
