Author Topic: mech to hyd head swap?  (Read 1906 times)
September 02, 2008, 08:13:03 pm
madrogers
  • 165
« on: September 02, 2008, 08:13:03 pm »
Good Day ,i have a 81 1.6n/a engine with a  mech head what is toast 11 mm bolts, have access to a 86(I belive) hyd head in good shape (12mm) bolts what do i need to do to swap heads, or can I ? Its for my winter beater rabbit so looking to keep it in a reasonable buget .
Thanks for any input on this situation.
Mark.
83 CADDY 1.6 TD WINTER
83 CADDY 1.9 AAZ SUMMER
Reply #1September 03, 2008, 07:16:58 am
Re: mech to hyd head swap?
« Reply #1 on: September 03, 2008, 07:16:58 am »
Quote from: "madrogers"
Mark.
Follow the white rabbit..
VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
http://www.dubnetworks.net/showthread.php?t=1748
The difference would be that your block has 11mm head bolts.. I dont see a reason why you couldnt use 11mm head bolts/studs in a 12mm head.
