The Cold Start Cable
Topic: The Cold Start Cable (Read 11565 times)
September 01, 2008, 08:00:14 pm
catlin_cava
September 01, 2008, 08:00:14 pm »
Does the Cold Start Cable need to be connected?
Catlin
2010 VW Golf City 2.0L "Hers"
September 01, 2008, 08:04:35 pm
blkboostedtruck
September 01, 2008, 08:04:35 pm »
yep! helps in starting when not at operating temp!
Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
September 01, 2008, 08:12:25 pm
Duster 5.9
September 01, 2008, 08:12:25 pm »
yes the new car manual states this on a new daily start up.
81 rabbit gas resting
81 rabbit cabby diesel n/a
85 jetta diesel n/a
85 golf diesel runs great
82 caddy diesel clean
82 caddy gas solid resting
and some parts cars
September 02, 2008, 06:20:21 pm
catlin_cava
September 02, 2008, 06:20:21 pm »
ok, if there an easy way to connect that cable, because it drove me crazy :evil: trying to hook it up
Catlin
September 02, 2008, 08:05:20 pm
Duster 5.9
September 02, 2008, 08:05:20 pm »
easy? lol! ahhh removeing the injection pump. easy for me yes. time consuming yes. actually if i ever remove another glo plug i will remove the pump, mark my word. back on track you need one of those long craftsman screw drivers and 3 fingers and maybe some wd40 for that little screw.
85 jetta diesel n/a
and some parts cars
September 02, 2008, 09:58:15 pm
Dakotakid
September 02, 2008, 09:58:15 pm »
Using a little telescopic, pencil sized magnet helps to establish the desired position and maintain the position of the "holed" retaining screw.
It also helps with the large washer behind the clip which holds the cable in the large rubber eyelet on the pump. Patience and fine motor skills are prerequisites.
September 03, 2008, 04:42:39 am
Turbinepowered
September 03, 2008, 04:42:39 am »
Just for kicks, anyone know where to
buy
a cold start cable assembly?
September 03, 2008, 07:08:24 am
Duster 5.9
September 03, 2008, 07:08:24 am »
post it in the wanted section someone may have a extra car sitting around with one.
85 jetta diesel n/a
and some parts cars
September 03, 2008, 07:48:05 am
VW Fox
User+
September 03, 2008, 07:48:05 am »
Here's a thought to consider: are the cold start device cables different between early- and late-style 1.6L TD injection pumps? Early pumps only have 1 position while later pumps also have the fast-idle position. Are the 2 positions solely a feature of the injection pumps?
1993 VW Passat (AAZ)
1992 VW Fox 8v (gasoline)
1980 VW Dasher 1.6TD (CY)
September 03, 2008, 08:24:55 am
stewardc
September 03, 2008, 08:24:55 am »
I removed the cable on my AAZ swap and It starts just fine.
September 03, 2008, 09:49:35 am
Duster 5.9
September 03, 2008, 09:49:35 am »
Quote from: "stewardc"
until what temp outside?
85 jetta diesel n/a
and some parts cars
Reply #11
September 03, 2008, 11:45:08 am
stewardc
Reply #11 on:
September 03, 2008, 11:45:08 am »
I only run it into the fall, but I've started it no probs down to 10 degrees F.
Reply #12
September 03, 2008, 05:12:11 pm
catlin_cava
Reply #12 on:
September 03, 2008, 05:12:11 pm »
Buddy, I'm in Northern New Brunswick...Tempatures go down below -50 with the windchill...you use eather to start gas motors...Any tips on starting a diesel in that cold?
Catlin
Reply #13
September 03, 2008, 05:37:45 pm
Dakotakid
Reply #13 on:
September 03, 2008, 05:37:45 pm »
A block heater if you have a power source.
A manual switch to run glow plugs.
Battery blanket.
Reply #14
September 04, 2008, 07:45:30 am
Duster 5.9
Reply #14 on:
September 04, 2008, 07:45:30 am »
what about the fuel then? when does it get to cold for it, or what do you people do when it gets below 0 to the fuel to keep it from gelin?
85 jetta diesel n/a
and some parts cars
