Author Topic: Parting out: 1.9 TD and 1.6 TD motor  (Read 5356 times)
August 30, 2008, 07:57:01 pm
« on: August 30, 2008, 07:57:01 pm »
everything is sold. Just working out the fine print. Thanks to all that applied
The 1.9 motor is presently running, the 1.6 is not. It's pump was leaking and then it managed to run away :roll:
These parts will be removed from the engines/car on monday the 1st and will be ready for shipping after that.
1.9 - unknown Kms, running, AC, EGR
exhaust mani - $100
intake - $80
T2, excellent shape. Virtually no shaft play, and the downpipe is clean so it is unlikely to be leaking oil. $200
Serp bracket, pulleys, AC compressor, no PS stuff, no alt - $100
EGR - $20
1.6TD pump. Resealed by a back yard mechanic who knows what he was doing - as I was told anyways. $150
Downpipe $50
1.9 injector lines - $40
Turbo return line $25
Feed line $20 (it's expensive to ship relative to it's value due to it's size)
1984 1.6TD
exhaust mani - $100
intake - $60
T3 - don't know it's condition yet $50-$150
1.6 TD pump - leaking - $75
1.6TD injector lines - $40
1.6 TD injectors - $40
oil filter flange - $30
Oil Pan - $35
Downpipe $50
Solid lifter head - need to check it out first
block w/ pistons and the works- $25 If you want a piece of the block it's $25. EI, the crank is $25, the squirters (w/ screws) are $25 or the whole thing is $25.
Let me know if you need something that isn't listed
I will ship worldwide
Reply #1August 30, 2008, 08:24:36 pm
blkboostedtruck
  • 1535
« Reply #1 on: August 30, 2008, 08:24:36 pm »
me me!
i'll give you a call on them!
tuesday
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2August 30, 2008, 08:39:36 pm
« Reply #2 on: August 30, 2008, 08:39:36 pm »
lol, I was wondering if you were going to message me. Do you want everything?
Reply #3August 30, 2008, 10:10:15 pm
« Reply #3 on: August 30, 2008, 10:10:15 pm »
Got the alternator for the 1.9 ??   And you said you *don't* have the PS pump, right ??
Opps... just saw you say no alt either.... ah well... should you ever run across..  ;-)
Reply #4August 31, 2008, 06:35:27 am
RabbitGTDguy
  • 1274
« Reply #4 on: August 31, 2008, 06:35:27 am »
Tyler...
Is the A/C compressor still available? It is serp...correct?  Also looking for a throttle cable from an AAZ MK3 or B3 car...
Joe
1972 VW Westfalia
Reply #5August 31, 2008, 07:15:16 am
blkboostedtruck
  • 1535
« Reply #5 on: August 31, 2008, 07:15:16 am »
Quote from: "RabbitGTDguy"
Tyler...
Joe
Joe I got some A/C compressors i been kicking around the garage!
no cables tho!
Duane
'66 variant 1500S
Reply #6August 31, 2008, 07:17:12 am
blkboostedtruck
  • 1535
« Reply #6 on: August 31, 2008, 07:17:12 am »
Quote from: "Vincent Waldon"
Vince,
 i have a couple power steering pumps !
Duane
'66 variant 1500S
Reply #7August 31, 2008, 07:52:45 am
RabbitGTDguy
  • 1274
« Reply #7 on: August 31, 2008, 07:52:45 am »
Duane,
It'd need to be a serp a/c compressor...namely from a b3 or early aaz mk3 car because of the line configuration. B4 and later Mk3's changed the line orientation a bit and won't work for the b3's former system...without some custom work.
Joe
1972 VW Westfalia
Reply #8August 31, 2008, 02:20:01 pm
blkboostedtruck
  • 1535
« Reply #8 on: August 31, 2008, 02:20:01 pm »
yes sir!
it's from a canadian 96 jetta that had a AAZ in it!
will that work for you?
Duane
'66 variant 1500S
Reply #9September 01, 2008, 07:13:10 am
Mutt78
  • 1
« Reply #9 on: September 01, 2008, 07:13:10 am »
I'll take an injection pump - is the resealed one a 1.9 or 1.6?  I need a 1.6, and I'd take the resealed or the leaking one.  I might be  interested in the T3 once you figure a price on it.
Thanks
-Tyler
Reply #10September 01, 2008, 06:43:41 pm
« Reply #10 on: September 01, 2008, 06:43:41 pm »
Hi Tyler,
All the above parts are sold, sorry
Reply #11September 01, 2008, 06:54:27 pm
« Reply #11 on: September 01, 2008, 06:54:27 pm »
Quote from: "blkboostedtruck"
Vince,
Duane
Just noticed this... thanks for chiming in Duane.... I'm guessing that shipping across the border would probably make it too spendy, but thanks anyways !
Reply #12September 06, 2008, 02:53:50 pm
FWD.MOTION
  • 170
« Reply #12 on: September 06, 2008, 02:53:50 pm »
is the 1.9 diesel engine gone?
BASELYNE
Reply #13September 06, 2008, 06:26:46 pm
« Reply #13 on: September 06, 2008, 06:26:46 pm »
no. but it isn't for sale
