Author Topic: New rabbit owner  (Read 5258 times)
Reply #15August 28, 2008, 05:30:03 pm
Dirtrag2
  • 298
New rabbit owner
« Reply #15 on: August 28, 2008, 05:30:03 pm »
Whoa  :lol:  for your rabbit to cost 9k in repairs you would have to blow the engine 3 times and 2 or 3 tranny's. not to mention maybe a paint job!  :P
then maybe you would hit 9k  :shock:
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #16August 28, 2008, 10:54:37 pm
79rabbit4dr
New rabbit owner
« Reply #16 on: August 28, 2008, 10:54:37 pm »
***drooling***
I WISH I had 9k to put into my wabbit... image all the things that'd be done... if only.
Reply #17August 29, 2008, 10:19:38 am
914turboford
New rabbit owner
« Reply #17 on: August 29, 2008, 10:19:38 am »
My understanding is that using starting fluid on a diesel is only bad if you are using glow plugs. If you disable your GP system it is not a problem. OTOH, catastrophic GP failure can occur if starting fluid contacts a hot GP. This can cause the GP to fracture, getting pieces into the prechamber and/or combustion chamber/cylinder. I don't know this to be the case from personal experience, it is just what I have read.
Reply #18August 29, 2008, 11:17:36 am
celticthor
  • 9
New rabbit owner
« Reply #18 on: August 29, 2008, 11:17:36 am »
Actually what happens when you use starting fluid on a diesel (I say this from experience) is that starting fluid is extremely cold and when it comes in contact with a hot GP it will actually cause the tips of the GPs to swell so when you go to take them out they break off causing MAJOR headaches.
I was using starting fluid on a daily basis when I had my 88 Ford IDI since it had several fuel leaks and the GPs were bad. Ended up getting all the GPs out except for 1 which broke
1981 VW Rabbit LS Diesel
1.6 liter
Upgraded radiator
Reply #19August 30, 2008, 08:41:47 am
79rabbit4dr
New rabbit owner
« Reply #19 on: August 30, 2008, 08:41:47 am »
so;
- ether = BAD
- starting fluid = BAD
I think I can stay clear of those  :shock:
Reply #20September 03, 2008, 09:29:02 am
arb
New rabbit owner
« Reply #20 on: September 03, 2008, 09:29:02 am »
Ether is starting fluid.
Yeah, its bad for functioning glow plugs, but why would you use it if your glow plugs were good ?
The only time I used it on an IDI was when the glow plug relay stuck "on"and burned out all 4 plugs.
Reply #21September 06, 2008, 07:04:47 am
drrtybyl
  • 146
New rabbit owner
« Reply #21 on: September 06, 2008, 07:04:47 am »
clean-looking car.  i am also a new rabbit owner.  are there any issues to look for that typically fail/break?
'79 Rabbit Diesel L
'94 Chevy 2500 6.5TD
'96 BMW 318ti
