Author Topic: Injector Pump  (Read 4221 times)
August 24, 2008, 06:28:50 pm
vw_tees
  • 2
Injector Pump
« on: August 24, 2008, 06:28:50 pm »
Reply #1August 24, 2008, 06:47:54 pm
blkboostedtruck
  • 1535
Injector Pump
« Reply #1 on: August 24, 2008, 06:47:54 pm »
would you ship to the U.S. if i won the auction?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2August 24, 2008, 07:02:15 pm
Injector Pump
« Reply #2 on: August 24, 2008, 07:02:15 pm »
why are there wires coming from the timing plug???  and is that a new style fuel stop solenoid, or just a fancy cover?
Reply #3August 25, 2008, 02:54:56 pm
vw_tees
  • 2
Injector Pump
« Reply #3 on: August 25, 2008, 02:54:56 pm »
This pump has come out of a late 96 plate golf. I think the pump has a electronic fast idle and also has an immobiliser on the back.
Hi blkboosted, I prefer not to sell to anyone in U.S as i've had a problem with shipping last time.
vw_tees
Reply #4August 25, 2008, 05:18:52 pm
Injector Pump
« Reply #4 on: August 25, 2008, 05:18:52 pm »
I have the same pump.
That is an immobilzer type deal on the stop solenoid. Basically you need a coded signal going to it to actiavte the stop solenoid. It is fastened on with sheer screws.
The wires between the delivery valves are hooked up to the start of injection sensor
