Author Topic: Boooooooooooooooooost  (Read 2286 times)
August 24, 2008, 03:20:51 am
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« on: August 24, 2008, 03:20:51 am »
ok! so as possibly seen in a previous post i made a little boost gauge apparatus that i THINK works well.
Like i said i get 10psi when i'm really giviner and when it's reving a little higher than i like it to.
Can i adjust this with the LDA?
i'd like the boost at lower end if at all possible without losing my t3 for a k24.
While i'm driving normally the dial will buzz on the pin but when it starts building boost the dial is solid and goes right up to 10-11 psi. (i have the screw turned out pretty far so no smoke on that one).
Could i have to "reset" my gauge? could it be reading much lower than it really is? Does this buzzing mean anything?
Thanks for your time,
Ed.
Ed
Reply #1August 24, 2008, 04:34:32 am
« Reply #1 on: August 24, 2008, 04:34:32 am »
buzzing usually occurs on gauges that were not normally meant for a car application.  but you can get something to go between the gauge & line that will 'filter' it a bit; it is nothing more than a restrictor.
the wastegate could be stuck a little bit open, bleeding the boost off.  either way something in your setup isnt working right.  you should be able to hit 15-18 psi no prob @ 4k rpm - mine will bury the 20 psi gauge with my foot planted @ 4k  :twisted:
mine has boost controller that disables the wastegate.  blow off valve = disabled.  fueling is turned up.  i suppose exhaust restrictions could also affect it...
Reply #2August 24, 2008, 08:00:15 am
Dirtrag2
  • 298
« Reply #2 on: August 24, 2008, 08:00:15 am »
X2 on what jtanguay said, my T3 ( on aaz )starts spooling around 2500rpm and will hit 26+ at 4200 on a stock exhaust and DP with fuel screw turnep up and 1.6 boost pin.  I plan to go with a 3" on my Fox projekt
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #3August 24, 2008, 09:01:26 am
« Reply #3 on: August 24, 2008, 09:01:26 am »
Of course the obvious question is have you adjusted the waste gate at all? Maybe it's set to only allow 10-11 PSI of boost in which case you can adjust the fuel all you want without increasing the boost a bit. Does it make more boost if you remove the line to the actuator(and plug the line)?
Reply #4August 24, 2008, 03:52:11 pm
Smokey Eddy
  • 3468
« Reply #4 on: August 24, 2008, 03:52:11 pm »
Ooooooo Thanks Jim. Yeah i knew i had to do that sooner or later. I was mostly wondering when most people make boost and what to do about my buzzer of a gauge.
I'm in the midst of making a 3" DP and 2.5 " dual exhaust that splits at the bottom of the DP. I need to do the waste gate like you all said. I plugged the blow off with a wine cork. I should take it off and plug it in the intake somehow but i don't have anything to weld that alluminium. All food for thought while I get my injectors popping at the right pressure and the time right on my IP with commuter boy this week.
Thanks to all.
Ed
Reply #5August 24, 2008, 03:57:55 pm
Smokey Eddy
  • 3468
« Reply #5 on: August 24, 2008, 03:57:55 pm »
Quote from: "jtanguay"
im glad my gauge goes to 50  :twisted:  :twisted: !!!!
quite a bit more work to fully utilize that though :wink:  :)
Ed
